I read a thread earlier about mounting the plates in the HEMMT wheels. The plates could be mounted on either side of the wheel for the fronts. There was some debate about this working correctly but I didn't see much resolution. 99% of the wheels I see are mounted with the plate on the back side of the wheel. Are you guys switching the studs to something else or using the stock studs and just knocking them out and reinstalling them like a bolt?
If not, let me know what you are doing. I'd rather the plate was on the backside of the wheel but I don't want it to be some sort of issue down the road. The plates I am running came from Roger Spurgeon out in Ohio.(probably spelled that wrong) The holes for the studs are larger than the pressed in shoulder of the HEMMT studs, that's why I ask.
The way this is put together is what I am talking about:
I did my rears like his too.
