HEMTT Wheel Question
Olly
Bristol/CT
HI, I finally started putting together my tires and wheels and after I bolted together one wheel and tire and I was on my second one I realized that in the runflat that there was what lloked like a place and hole for the air valve now I've heard conflicting things on whether it's important for it to be properly lined up with that or not so before I go and take the first one apart to fix something that may or may not be a problem is it? Does the air valve need to line up to the space on the run flat? Thanks for any help.
charlesmann
713
Temple, Tx
When i did my lmtv wheels, even though i rmvd the run flats out of the few that had them, they were lined up with the valve stem. A couple 14R20s on combat wheels had R/F in them and they too were lined up. It might not matter, but its only 1 tire a d if by chance it does make a diff, then its already done and the rest can be put together. Its better to have and not need, than to need and not have.
Olly
Bristol/CT
Thanks for the response now that I've had a few hours away from it I've been thinking I may just rip it apart tomorrow and fix it. Hell, I've already done 6 of them the right way might as well fix the seventh at this point. As you said it's better to be prepared than not.
gringeltaube
Staff Member
2,269
Montevideo/Uruguay
I've heard conflicting things on whether it's important for it to be properly lined up with that or not ...........
All RFs have channels and/or holes and are designed to never block the air valve, no matter what position.
I would leave that first wheel as is.
