Ibexe666
- 6
- 18
- Florence, South Carolina
Oh **** i forgot to mention its 4x4 not 6x6
And still be able to tow/haul and go cross country...At this point, my bs flag is waving proudly! Pictures or its just a pipe dream.
Why in the **** would you build a 5 ton bobber to go mudding, hAs to be diesel powered making over 1K horse power out of a no production block!!! You have no clue what trans to run, much less axles, for under $150K. On and this think has to survive with out needing to be rebuilt every couple of runs!
Don't forget being able to blow a transfer case apart with a stock motor.At this point, my bs flag is waving proudly! Pictures or its just a pipe dream.
Long enough to pickup one of those fuel pumps of yours... If you're still selling.Spicer P8516 16speed Gear ratios are reverse 6.39, 1st 6.53, 2nd 3.42, 3rd 1.86 , 4th 1.00
On the auxiliary
1st2.40 2nd 1.19 3rd dir 4th .84
THe brownie is hooked to it and yes it is an air shift. I scored one years back for $300.
Weight is 675lbs
Length is 42" long
Width is 22"
height 20"
1 3/4" input shaft
Just put a carbide ceramic puck clutch in front of it and It won't break. Granted you don't do anything stupid, but with the way this thread has gone and your responses I think the odds of you not doing something stupid with it are slim to none. I saw no pics on the thread so I had to add one. Speed and Power is money, how long can you afford to be broke?![]()
Use biodegradable UTF like they use on boat hydraulics, no EPA worries then.Hmm thinking back to the hydraulic drive makes me think of high pressure hydraulic dangers and leaks .-. Epa fest if something goes wrong still trying to figure out the advantages and disadvantages over a hydraulic vs a normal drive system
lol i thought about biodegradable fluid but then again going back and looking at the size and weight of a system for full hydraulic drive and for the hp motors i would need it wouldn't be worth it.Use biodegradable UTF like they use on boat hydraulics, no EPA worries then.
Aaron Z
What, 200GPM at 10,000 PSI is too much of a pain to deal with?lol i thought about biodegradable fluid but then again going back and looking at the size and weight of a system for full hydraulic drive and for the hp motors i would need it wouldn't be worth it.
