High idle solenoid
SPECIALTYLC
Washington
The high idle wont turn off on my 1008. Was working fine until this week. When I disconnect the wire it returns to normal. What controls the solenoid? Is it a sensor or is it in the glow plug card?
1,168
Look at figure F3 in the -20 TM.
mangus580
282
Western NY
I think there is 3 temperature switches. One, activates the idiot light, one glow plugs, and one the cold advance - high idle.
Check the TM to confirm, but I believe the drivers front side of the engine (on the head) is the idiot light, drivers back of the head on top - glow plug.
I dont remember where the other one is... believe its on the side of the passenger head.
SPECIALTYLC
Washington
I found it. No thanks to the TMs, they dont have a picture or say where to find it. Its on the passenger head rear,next to the exhuast manifold.
1,168
Figure 46 in TM 9-2320-289-20P identifies the sensors and shows the locations.
1,814
Wonder if one could unplug the sensor and pipe in a switch. I don't need the high idle here in the heat, it would be nice for extended idle time.
Dodgeman1941
W. MI
Last weekend we were using the inverter that I have in our blazer to run the lights in the tent that houses our military display at an event. We run it for a half an hour every 4 hours or so to recharge the battery. At the last outing that we did this at the blazer "loaded up" really bad and we killed every mosquito within a half a mile when we left. This weekend I tried a trick where I unpluged the high idle wire and plugged in a jumper to the 12v and it worked like a charm, recharged the battery better and no smoke cloud when leaving. I'm thinking about adding a relay and a button on the dash to do this with a flip of a switch.
howardc
KY
Could anyone that disconnected the Cold Advance and put in a manual switch elaborate? ie, location of manual switch, pics, etc. Thanks in advance!
Barrman
1,585
Giddings, Texas
You can mount the switch inside the truck anywhere you want.
The stock automatic switch is on the passenger side head, all the way back near the firewall. Below and to the rear of the #8 fuel injector. You can maybe get to it from the wheel well. The exhaust down pipe is in the way to get to it from the bottom. Laying on the engine works pretty good for me to get to it.
There are just two wires on the switch. Constant hot power anytime the ignition is on and then the green wire to the IP.
If you want to retain the stock cold start advance and hi idle function. Which I suggest you keep. Splicing into the green wire at any point from the switch described above to the two plugs on the IP would work. That way it will work without you thinking about it and at times you want a faster idle.
howardc
KY
The high idle on my truck has been acting up. If my truck is in P or N, it sounds like it's at max RPM. In Drive, the pedal doesn't return to idle. If I splice into the wire and keep the stock function of the switches, would the manual switch exorcise the demon in my truck until I turn it on and reactivate it? Ideally, I would like to have the function for warm ups, but I don't really need it at 65 mph.
cucvrus
9,643
Jonestown Pennsylvania
Have you tried removing it and cleaning everything well. There is a switch that tells the fast idle to engage. Have you checked the switch? I had one stick and a good cleaning was all it took to get it back in working order. Just a suggestion. This is NOT a cure all. Just a thought and easy enough to try. Have a Great Day.
howardc
KY
I will try today. Is that the one on top of the engine or the one on the passenger side rear engine?
1,168
I would look at your throttle cable, it may be sticking.
The high idle is not that high(should not be).
howardc
KY
Took it out for a test drive during lunch today. It started happening again, so I unplugged the green wire from the high idle switch. It performs fine now, tried several times to reproduce the stick but could not. I guess I will try to clean the old sensor when I get home.
nyoffroad
631
Rochester NY
Well so much for my thought of a frayed throttle cable!:p Clean it up and readjust it with a straight screwdriver, just be CAREFULL of the fan blades!!!
