Loose Boots
- 19
- 3
- nebraska
Hey guys, so heres whats happening. Installed a new fuel injector pump. I have fuel flowing all the way to the pump. If I remove to top hose and crank fuel will squirt out. Fuel shutoff solenoid is working with 24v. First night of installation I had fuel, but since then nothing.
I was told to disconnect the fuel lines from injectors and crank until I saw fuel. I have had no fuel not even a drop.
So what am I doing wrong?
Should I keep all lines attached and only do one at a time?
do I remove it completely or just enough to leak?
Is the fact that they are all completely disconnected the reason nothing is happening?
I am also interested in the reasoning behind how to do this properly, I learn and remember better if I know not just what to do but why to do it and what happens if I do it wrong.
I am learning, so please explain things as if I was a 5yr old with no clue what he's doing. I'd rather you tell me some little thing I already know than not tell me something I don't.
Thank you for any assistance.
1988 1097 HMMWV 6.5l non turbo 4spd
