HMMWV directional tires right?
KansasBobcat
San Antonio, TX
Just wanted to add that both of my HMMWVs have the chevrons pointed forward and work fine. I did not flip them that is way they were on M1101/M1102 trailers that I bought. Just decided to do it and it does look better. Who cares, right?
saddamsnightmare
80
Abilene, Texas
June 13th, 2015.
And while you are theorizing in the tires being mounted one way or the other, remember early in WWII the White scout cars used basically ag pattern chevron tires. If they were mounted directionally, as they are on tractor rear wheels, they only pull well in forward motion, and can really stick you in mud in reverse. I suspect the different mounting placements on the HMMWV may be similar, as there is a distinct pattern to the V's in these tires.....:confused:
gaducker
Newnan Ga
You can just flip the tire over without removing the runflat however the valve stem will be pushed up against the inside of the runflat and you will not be able to get the air out very quickly. I used a grinder to remove enough rubber to let air out, They balanced out like that so I have been running them on the street for almost 2 years like that.
