hmmwv exhaust heat shield noise???
neos
Fort Lauderdale, Florida
I get a vibrating high pitch noise on my 1989 M998 at about 35 mph and goes away at about 40 mph. it sounds like an exhaust heat shield noise. I check for loose parts but can not find anything. Any ideas? Thanks
dmetalmiki
2,028
London England
That could be almost anything. You will have to go through the vehicle and check everything for tightness and fit. You could start from where you think the noise eminates from. But vibrations can travell through a lot of compnants. Let us know the end result.
gcbennet
Trenton, ON
On my truck one of the welds on the exhaust crossover pipe shield had cracked through and it made a **** of a racket when it vibrated. As always with my truck it wasn't obvious and I had a **** of a time finding the source of the noise.
Retiredwarhorses
4,182
Brentwood, Calif
thats the normal spot...remove the shield or put hose clamps around it. Some of the crossover pipes NOS don't have that heat shield....IMHO, it's a nuisance.
papakb
1,185
San Jose, Ca
Had exactly the same problem with the heatshield on the crossover pipe. When I originally got it the shield was welded on the wrong side of the pipe and the welds I did when I switched it over didn't hold. I ended up hose clamping it and haven't had problems since.
neos
There are no heat shields on any of the crossover pipes (should I install one? Would it make a difference? )
However I did find a loose heat shield attached to the transmission oil stick. Just need to find a way to secure and test....
86humv
501
Texas
The small dip stick heat shield clips and bolts to the big shield for the right exhaust.
irondad2009
kentucky
I have a heat shield that is loose on pass rear. It is broken off at the rear. I need to put two exhaust bolts in and this thing is really in the way. Can I just take it off, and leave it off.
