05blackduramax
- 8
- 18
- auburn,indiana
Sundowners9000 did you find a good place to get a replacment pump?
Ah, you stated that nothing came out of the lines when pulled from injectors. It must be, if it runs. Tighten all lines at injectors except ONE of the easy to reach rear ones. Put a waded up paper towel under it and crank. Maybe you just have some air that needs to finish bleeding? It could be several things.The other ends are under the intake. I could get a few off possibly but not all without taking it all apart. But this is the second time it's done this. It has always ran just fine once it's running.
