HMMWV Overheat Q's and pictures
McSpeed
293
Palmer, AK
AH...this makes sense. Per that posted manual, this explains why the fan kicks on and off. I usually notice this when I'm cruising at 55 or so. This summer I've been using the truck to take my boat to the lake. I'm on the throttle pretty steady to keep it pulling, which may have it in kick down mode. This is why it goes on and off:
B. TIME DELAY MODULE TESTING
a. Description
The time delay module sends a delayed
signal to the fan clutch solenoid for delay
of fan actuation to provide needed
horsepower for engine acceleration. During
normal engine operation [(engine coolant
temperature below 230°F) (110°C)],
current flows through the time delay module
energizing the fan solenoid circuit This
provides hydraulic pressure to overcome
spring pressure thereby disengaging the
fan clutch.
When engine coolant temperature exceeds
230° F(110°C), current is interrupted by the fan
temperature switch. This interruption of current
causes the time delay relay to open, thereby
de-energizing the fan solenoid circuit and
allowing the fan to engage for additional cooling.
If the kickdown switch is actuated during fan
operation, the time delay is activated,
disengaging the fan for approximately 20
seconds and providing additional
horsepower. If the kickdown switch is
activated again, an additional timer within
the time delay module prevents the
disengagement of the fan until 20 seconds
has elapsed allowing for adequate engine
cooling. After the timer completes its 20 second
cycle, the kickdown switch can be reactivated
and the fan will disengage, providing additional
horsepower.
David172
Columbia/Tennessee
Ok, so they sent me one that looks and fits like the OEM one I had. The temp now rises to 220 before the fan clutch engages. It no longer cools down to 200 but cools to about 218. The fan re-engages at about 220 keeping the temp at 220 or below at all times. I also notice the fan only runs for short periods of time now since it is obviously not cooling the engine temp down as much. On my normal 20 mile trip to the farm the fan clutch engages a couple of times when it used to come on 3 or 4 times. Does all of this sound ok/normal to you? Should I have any concern about a continual engine temp of 220? My coolant is clean and the truck shows no signs of overheating. Thanks for your help.
Retiredwarhorses
4,606
Brentwood, Calif
220 is the normal range....don’t trust the gauges to be exact, they aren’t.
sounds like a normal running truck.
G3isMe
46
Texas
I note your new to forum? Just got a Hummwv? These cooling issues can be learning experience to new owners and old ones too. ...
As the 4 Star stated, unplug it and drive it. This is all you got and you have to get back to base or pick up supplies (beer) or dodge some bullets. It shouldn't ever get too hot. It should regulate on the mechanical thermostat and that too is a test. (may run a bit cooler) If it runs hot pushing the 240 mark, you have other problems, like clogged up anything, thermostat or a pump. (got water?)
.....CAMO
Yes I am new to the HMMWV. Six months ago I discovered GovPlanet and didn't own any HMMWVs.....Now I own two.....:mrgreen: .
I am grateful for everyone's advice, especially yours and Retiredwarhorses. I have already learned a lot from all of you guys on this and other threads.
Duly noted about the multi-meter. I am going to dig mine out. As per the General I will disconnect my TDM until the new parts arrive. Do you know if any quality thermostat made for a GM 6.5L engine work in the HMMWV? Kascar lists several thermostats but I can't see the difference (except the one for the 6.2) unless they are different temp ratings.
Your advice is most appreciated.
https://real4wd.com/store/catalog/search.aspx?keywords=thermostat
Milcommoguy
2,414
Rosamond, CA
Things to think about... IMO. COOLING SYSTEM
Just won the rig? Study up on the TM's or manuals while waiting for the EUC. Good chance the dealer / sales person NOT going to do a walk around, a test drive or point you to the book in the glove box.
Flush the system really good. Rig maybe new to you. Well, some parts might be almost new...Ah, not so much. Just got it in...a sweet "89" model?? from sitting for HOW many years.
Use quality brand name parts. Going cheap could take out the whole engine.
Buy from reputable suppliers. They have been there, sold that. If it doesn't make sense ASK questions.
Stay with recommended temperature ranges for thermostat. Going to a 170 or 180 temp engine will not be happy and you'll thank me in the winter.
You got the STAT out? Run it up in the driveway real quick, make a mess, checking pump flow. Shut it down
Check and clean crud between radiator stack.
Straighten fins works better. Slow and PITA.
Pressure check cap and system, 15 PSI and holding. Check with engine running too. Could be other issues. Didn't want to hear that one.
Easy does it with coolant reservoir tank. Fittings maybe brittle / cracks in unit? Bring the check book.
Check and /or replace heater control valve. Good place for a small leak. Any leak is system leak. BAD NEWS
Replace all hoses. New clamps. Cheap insurance, a feel good moment. Blow a hose and the ZONE may not have it. (I also add an extra large & small clamp, not tight, for trail spares just it case, fuel line too)
Nice to have the lower stainless radiator to engine manifold. Less rust too. SHINNY
Add the fan clutch quick disconnect fittings / hose. Make belt changes a WHOLE lot easier than a Rubik's Cube.
Check fan clearance to shroud. A bad engine mount could blow the wind out of fan and day.
Run proper mix of coolant. More is less.
OH...did I forget belts.
No guarantee to the above info. Comments free. It worked for me. Add to it, cuz I am sure I miss a lot.
When the hood is up use that study time above to get all "JIGGY" with all the other going on's. Wiring, hoses, modules, valves, pumps, nuts and bolts.
Running cool now, CAMO
G3isMe
46
Texas
I found the correct, made in the USA, thermostat at a local auto parts store for the 6.2 L. It is a Stant part number 13479.
G3isMe
46
Texas
Gentlemen, we have "leaf blower" engagement. Today I removed the line from the Cadillac valve and blew air through the line to engage the fan. It took quite a while and a lot of blowing to get the fan to move back and forth with regularity. I also lightly rapped on the clutch with a rubber mallet and a piece of soft wood a few times. After I did this for about 15 minutes I started the engine and unplugged the TDM. The fan engaged completely with the sound mimicking a leaf blower. I had never heard the fan on this truck sound like that before so I am pretty confident that part of my cooling problem was the fan not engaging properly. I have ordered a thermostatic switch from Kascar which should arrive soon. Hopefully replacing that will cure all of my cooling issues. Thanks again guys for all of your advice in this thread.
ltrpd
Columbiana, OH
War horses, What is the process of unsticking the fan clutch? Do you have to remove radiator stack? I think my 6.5 NA clutch is sticking, it moves a little but the fan does not make roaring sound that it used to make. Any help would be appreciated
NormB
119
Hampshire, TN
I’m wondering if your cadillac valve is bad and/or your line from it to the fan needs to be bled. If it moves a little, it should move enough, or maybe there’s some oil on the clutch friction plates.
Just thinking/typing out loud here.
I’m sure it’s in the manuals.:?
G3isMe
46
Texas
I am pretty much in the same boat as Itrpd. I've replaced the thermostat, the thermostatic switch, and blew 90 psi into the line from the Cadillac valve to the fan. The fan moved when blowing the air into the line after about 15 minutes of doing that. However it is now not moving very much at all when disconnecting the TDM to engage the fan. Initially the fan did produce the "leaf blower" effect but it is no longer engaging that well. Even if the fluid level was low or air was in the line, isn't the fail safe mode for the fan to default to On/Engaged so it would be on all the time vs. off, i.e., not engaged? I am still learning so my apologies upfront for the, most likely, redundant questions.
Retiredwarhorses
4,606
Brentwood, Calif
I drive so many of these truck I’m able to see the differences in fan clutch operation.
what is 100% is that none seem to be identical. I have a truck or 2 that when hey engage, it’s like “****!”
clean underwear needed, and then others that just make a nice smooth transition, what I’m most concerned and my only concern is if it’s working and dropping the temperature as it should.
There are friction plates in the clutch, so normal wear is expected. If your clutch was sticking, it would stick locked closed, not disengaged and free wheeling, they fail in the locked position.
One thing I’ve seen is folks who put the fan blade on backwards...that will cause major issues.
Ant929
Jupiter, Florida
Do you have any idea why the fan would come on at 185? I have put two different Temperature switches and a new Time delay module. The fan is off on a cold start and as soon as it hits 185 it comes on and stays on. I have also checked it with an IR thermometer and it is truly at 185.
aconway
56
Kansas
If you hit the tank and thermostat housing with a laser thermometer and saw a >20* difference, I would not suspect the fan thermostat or engine thermostat is bad. Around 185*F is normal for internal combustion engines (diesel or gas). The boiling point of water in open air at about sea level (1 atmosphere) is 212*F (100*C) - with antifreeze it shifts a bit higher, and with the closed cooling system and a good radiator cap keeping the pressure in it rises a bit more too (without knowing what you radiator cap is regulated to, I can only guess your boiling point is about 220*F - so this is why the other commentor has said it is "not normal" he's right - it's dangerous for any water-cooled engine to be indicating a water temperature that high).
If you are seeing 240*F at any time, be assured that you should also be seeing a bunch of coolant flowing into the over-flow tank and eventually on the ground as that overfills - at 240, just about any water-cooled engine would be in full-on boil-over.
If you start with the engine cold, remove the radiator cap and then start the engine and let it get to temp - I'll bet your fan tuns on and then off without the radiator spewing coolant all over the place (which would mean it's not boiling anywhere in the cooling system). I that is the case, you can be assured that you can call BS on the gauge. Make sure that you take the radiator cap off when it is >>COLD<< if it was run hard at all and got to temperature before you remove the cap, you will lower the vapor point of the fluid and cause a spontaneous boil - which will eject sticky (glycol is a "sugar") boiling water all over your hand, face and chest (and anyone next to you). Think of it like being covered in boiling napalm... Treat it with the due respect!!!
I think either your wiring is bad, or you have a gauge+sender combination issue as another commentor has suggested. Be aware that your indication equipment can be messed up and the rest of the system can be running just fine. They are separate typically for this reason.
Great reply.. thank you sir. !
Mstng65HummrMan
21
Eastlake California
Today I drove mine about 10 miles and this is the gauge reading, pretty close to 240 F with an ambient air temperature of over 100 this afternoon. I lifted the hood when I got home and the fan was running. After reading the similar overheating thread and reading the cooling troubleshooting section of Tech Memo "TM 9-2320-280-20-1", the trouble shooting methods make much more sense to me know. I am going to try disconnecting the TDM as per Retiredwarhorses advice and blowing air into the fan clutch line as I now think my fan is spinning but not engaging.
My ‘02 M1035A2 cycles just under 240, engages the fan and drops to 224, then rises to back to just below the 240 line. I verified the fan clutch to be operational. The TDM was disconnected when I received the truck from GovPlanet. I performed all the fluid and filter changes. I have driven about 500 miles with this, tried another temp gauge, replaced the sending unit and fan switch with Hummer Parts Guy parts, replaced the thermostat (HPG part), replaced the Cadillac Valve and TDM (no effect on the cooling cycle), flushed the Radiator three times, and replaced the lower metal coolant tube with a stainless steel one. I added WaterWetter to the coolant. I have a Gano Filter in the upper radiator hose that traps particulate and can be removed and cleaned (3 Xs so far with sludge and small rust chunks removed from the system) and after all this the temp range while driving remains unchanged. Ive read that these trucks routinely operate in the 220 to 20 range but would like o see it cycle at 225. What say you guys?
