HMMWV replacement windows...glass or polycarbonate?
Mogman
10,564
Papalote, TX
Here's an interesting article about laminated vs tempered glass windows in vehicles:
Good point, BUT you better have a tool specifically designed in your hand when you crash or you will unlikely be able to break the tempered glass, also I doubt the article was about vehicles that had simple sliding windows, I always figured the doors would simply pop off in a serious crash anyway.
Autonomy_Lost
1,554
Pennsylvania
Or a utility knife to cut through the soft top lol!
Action
1,564
East Tennessee
You can take your shirt off and wrap around your hand to break tempered glass. The tempering makes it break into lots and lots of tiny pieces.
if you try to get out through a laminated windshield, you will likely have to knock the entire window out. Laminated sticks together when broken.
papakb
1,196
San Jose, Ca
Most EMTs and fire departments just use an automatic center punch to break out tempered glass. A cheap trick they learned from car thieves.
Autonomy_Lost
1,554
Pennsylvania
I'm currently waiting on quotes for the glass from 2 local glass shops.
In the mean time I will also need the gaskets. I can't find them anywhere, not even at Mac Motors. I found some generic rubber U-channel on McMaster Carr:
I'm not sure what size I will need, but I should be able to figure it out when my doors show up. If anyone has dimensions on the factory gaskets that would be helpful.
papakb
1,196
San Jose, Ca
What thickness glass did you ask for quotes for? Just buy the channel of the same thiclness.
What thickness was your original glass? Go for the same thickness as your original or you might find the new stuff doesn't fit your frames.
Autonomy_Lost
1,554
Pennsylvania
3/8, but what about the other dimensions like overall thickness and width?
Mogman
10,564
Papalote, TX
I think he was talking about getting some "universal" channel and needs the actual frame dimensions, he should wait until he gets his doors, that way he will actually see what he is dealing with, the actual glass dimensions are not "even" IIRC, as to say I think one dimension was something like 14-1/16" not 14"
Action
1,564
East Tennessee
You are correct about the odd size. I think i have a loose one. I will look tomorrow.
The factory seal is thin on the glass edge. If you get generic, you will need to adjust window size.
Mogman
10,564
Papalote, TX
You may be thinking you need to replace the window seal when just about everyone re-uses the original, If for some reason you think that will help the rattling or the fact you need to wear a slicker suit when it rains you will be wrong..
TOBASH
3,963
Brooklyn, NY
As a temporary solution to cover the defect and create a functional closed window just go to Home Despot or Lowers and buy plexiglass and cut to size.
It will last long enough for you to get correct glass
Autonomy_Lost
1,554
Pennsylvania
If anyone is interested, I got one of the quotes back from a glass shop. They quoted $95.70/ea for laminated glass, or $47.12 for tempered glass. Still waiting on a quote from another vendor. You guys think laminated is worth twice the money?
TOBASH
3,963
Brooklyn, NY
Laminated is safer.
Coug
4,803
Olympia/WA
our doors aren't as difficult to remove during an emergency as your average automobile door is (and if the accident is bad enough to cause the body to crumple, the door is't going to be stuck shut), and the windows aren't really large enough to drag someone out of if there is an emergency anyway, so I'd say that being able to break them during an emergency isn't as big of a deal as it is for a civilian car.
Mogman
10,564
Papalote, TX
I would not use laminated in side windows unless that was all I could get, tempered would be best and I would certainly not pay more for laminated if I had the choice.
The flip side of laminate is de-laminate
Autonomy_Lost
1,554
Pennsylvania
Everyone makes good points. I think either would be suitable, so I'm leaning toward tempered at half the price. I'm not exactly made of money lol.
