HMMWV Steering Wheel Puller
ikoinu
21
Los Angeles, CA
Looking to pull your steering wheel? This might save you some time.
The early original steering wheels put on Humvees were terrible. Very narrow, felt like you were grabbing nothing.
The later models got a thicker wheel which feels more appropriate to the vehicle. These can be found on Ebay, and are not very expensive, $100+.
The one in the picture had this info on Ebay: NEW STEERING WHEEL M998 HUMVEE BLACK 12446803 2530-01-411-2729
Hammers don't work, neither do gear pullers. But this guy does:
OEM 25200. Think I got it a while ago from Autozone. You could also get a military puller from ebay, but this is easier to find and cheaper to boot.
Notice how narrow this allows the puller bolts to be placed. This is why this one works when others don't.
The bolts that come with it don't fit the Humvee steering wheel. I taped the ones that do to the package so I don't lose them.
M6 1.00 x 70 bolts.
M6 washers. (The ones in the package might fit, but I doubled up just in case.
New wheel. Late model HMMWV factory.
Old original wheel. Very uncomfortable. The damage was done by a mallet trying to get it off. I forgot I had that puller.
Newer wheel: .92"
Original wheel: .63"
papakb
1,186
San Jose, Ca
That's a pretty standard automotive wheel puller. What the OMS shops use in a puller with a "C" shaped piece that looks like an overgrown retaining ring that grabs the wheel below the plastic hub. I mounted a black Hummer leather wrapped wheel on mine and it's much more confortable than the stock wheel.
Could you post some information about how the HMMWV wheels diameter has changed?
ikoinu
21
Los Angeles, CA
Lucky! I knew that there was a leather H1 wheel, wanted it but could'nt find it.
The steering wheel diameter is identical, just the rim thickness is different.
When I get a second I'll check the rim widths with a caliper.
Update: Posted pictures of the width difference.
If anyone has the part number of the original green steering wheels pictured, I would like to post it here for reference.
Radium
Ottawa
I know this is an older post, but it really helped me out. I have an original skinny green steering wheel on my M998, and I was unsure if the black steering wheel offered online would be different. The pictures helped me see the difference.
juanprado
2,806
Metairie/La (N'awlins)
black one fits in place of the green one easily. You can use the free rental tool from O'reilly's. No special puller needed. Pictures and details on my thread:
see post 109
After I did mine, Someone posted a picture of the newest horn button with a bugle imprint. Looks cool! Might want to consider changing the horn button at the same time. Mine was plain black.
New style available direct from AMG for I think $45 from their new website.
