Holy oil cooler lines batman!
DrJekl
Clarksville, TN
I looked at Advance Auto's web site and while they do not sell the 84-86 cooling lines, they do sell the 99 model lines that go to your oil cooler out front. They run $20 each, the connectors for the block are $5 each. I brought in my radiator and lines but found I was missing the little retainers that hold the lines in place. So I ordered new ones for $5 each from AA and am going to install the whole thing this weekend and get away from the old style set up. I think I'll do the same for the transmission.
southdave
ripley, oh/TDY Lordstown,Oh
Dealer only or not there has to be a hose supply company that can make them.
I try that, ran into issues with the compression fitting. the lent and the o-ring for the oil cooler where the enter the raditor noone wanted to do it.. I cut the bought 20 bucks of hose and clamps and I was back in bussiness.
the alternative is use a pex heat exchanger with some Tee's off the heater hoses.
http://www.ebay.com/itm/10-Plate-He...t=LH_DefaultDomain_0&var=&hash=item7b68f00436
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Good luck on the adapters that thread into the oil filter casting. I've replace both them and the lines twice and they leak after a while. I'm changing over to hydraulic hoses. This was on a 93 3/4ton chevy.
