jw4x4
- 6
- 38
- Dayton, Ohio
Oh, come on Eric. What IS the answer? Enquiring minds want to know! ( I am bracing myself for this one)
My ex Air Force Chevy Van 6.2 with turbo 400 was lousy on heat the first winter I drove it. It would throw heat but barely luke warm. $7.00 for a new 180 degree thermostat and it throws plenty of heat at 0 degree's out without a winter front. The old thermostat was fully open at 125 degrees we stuck a digital meter probe into the open thermostat's open holes. Also the 6.2 Diesel thermostat's have a small hole on one side with a piece of flat metal hanging from the hole, air causes it to drop and let air pass through it and waster pressure from the pump forces it back into the closed position so it doesn't supercool the engine. If the thermostat you buy isn't like what I described it is designed for a gas engine vehicle and it can't purge the air until the thermostat opens meaning somewhere else in the engine some part of the cooling system is bare metal with no coolant touching it and carrying the heat away, it might seem like a small item but is critical to long term proper operation of your engine. It takes a while for the engine to fully warm up but everything else being right it will defrost the windshield when it kicks off high idle. Not hot-hot but enough to defrost it. When you drive it then it really warms up and throws heat, it also allows the engine to run at it's designed temperature.Started at -18, but doesn't really produce much heat. Gotta find me a winter front.
