How do you change a tire
blisters13
78
Beaumont in SoCal
I don't think you were wrong is using the pick, or at least not alone. a friend of mine who was an engineer in the army asked if the truck came with a "pick o matic".:-D apparently they have been used more than once to change a tire.
Bad idea to slam anything with an edge into the side of a rubber tire??? Proper tools save lives.
roscoe
Spencerville, Indiana
I just repaired a couple of tires this week. One just an hour ago. I found the hardest part (without real tire tools) is getting the split ring off. After that, I thought the rest of the process was easy. I can see why you would want this type of wheel/ tire/ tube combo for repairs in the field.
crasheej
Hermitage,MO
When in the field we didn't have a cage so we used a chain . You ran it around and through the holes not to tight or you have an other problem . Locking chuck and a long air hose. Never had any trouble. Maybe luck was with us those times. But you do what you have to do to get the job done and try to stay out of trouble.
panzerjunky
san diego ca
Thanks for the replys Fellas
I ended up not blasting but using a needle scaler and an orbital sander and they look great.
I did although more to refresh my memory and just to be shure I had the know how if needed in the field I did it like I remembered us doing it all those years ago I took a sledge and beat strait down on the sidewall of the tire to lose or break the bead then the matox to clear the bead and remove the ring the rest was easy when it came time for the ring I placed it flat on the garage floor it did not lay 100% flat so I tossed it in the corner and put on an nos ring I had then a chain was losely wrapped around the tire and the tag ends were held together by a padlock ( I remember doing that in the afore mentioned mud at Ft. Carson it aired up fine and is now my spare But..........I 100% agree with all the other fellas on this post get the proper tools as I have since done they make the job a lot less stress full also just get another tire and rim and toss it ( ok Heave) in the back of the truck hen you go out to the back country if you go through 2 tires you are wheelin way to hard and its time to go home.
Thanks again for that very informative post
Jerry
kfrosty
Belmont, NC
I have a couple of questions on this as I'm getting ready to change to some 16 tires and I don't have a cage.
What are the chances of the 5 ton wheel lock ring actually explodes into shrapnel? If that's the case then it doesn't seem the cages are even safe?
Also, if they can fail, what's the difference in just airing up a tire low on pressure?
After reading this informative post, I'm thinking of only airing up with the wheel or tire mounted and either putting an excavator bucket up against the wheel or a bobcat bucket.
I know the thread is old but thanks for this. Glad I found it. These wheels and tires are so heavy and I only air up to 40psi most of the time to help with the ride, I would have never imagine this type of problem.
1,138
If you're coming to the Ga Rally, I have 2 cages and I need to sell one. Really cheap. $50? I can get pictures today.
I have never heard of a lock ring turning into shrapnel. If the ring isn't properly seated in the wheel groove or if the lip of the tire bead has an issue, when inflating, it may force the ring off and obviously with a lot of force. I've never heard of one turning into shrapnel.
In theory, once the tire bead has seated on the ring, the ring is locked onto the wheel by the tire. A flat tire that is still "beaded" can't let the ring come off, whereas when you're inflating it for the first time, the bead hasn't seated on the ring.
I have had a couple of flats where it looked like the bead wasn't flush on the wheel, those I used a remote chuck on just to be on the safe side.
Goes without saying you should own a remote tire chuck.
You're using the site the right way, you're searching for your answers and bumping relevant threads.
Kaiser67M715
26
NH
when pulling the safety ring off, be sure to inspect it and the groove in the rim carefully, scrap out any rust, and make sure the ring has no cracks or is heavily pitted with rust-because if it is cracked or pitted too much, it could end up forcing itself off the tire-even if the bead is seated correctly.
I know a couple guys who mount them right to the truck, ring facing in towards frame and air them up-any damage should then be contained by the truck-if you don't want to damage your truck, think of it like this-whats more important, you or the truck? obviously there are multiple safe ways to air up the tire, and you can choose any which way you desire - I'm just lending another way for those of us that don't have a cage, or excavator handy.
and I'll put this here, for those who don't want to back-read, most tires on a M35, M37, M715, and 5 tons are of the safety ring type-you have to get the bead of the tire below the ring to remove; otherwise you risk damaging the ring, this is not like a split rim, where you can remove the rings after pushing the bead back a little bit.
1,138
I'll take one of those cages for 50!
I only have one and kfrosty has first dibs on it, he pm'd me before you responded. He's gonna' see if he can get someone to pick it up from me and bring it to him or closer to him. If it falls through with him, you're #2.
Here it is. Simple cage, built at Warner Robins AFB. I've done a bunch of deuce 9:00 and 11:00R20's in it, but I need to measure it and see how big a tire/wheel can fit in it.
277
Belton, SC
Sounds good. If he doesn't want it I'll buy it and either just come get it or pick it up at the rally. 11R20 is all I need, I don't really plan on switching from the stock rims.
Charles
Sent from my SAMSUNG-SM-G930A using Tapatalk
1,138
Charles
Check your inbox, sent you a pm yesterday.
