It gets complicated, so it's hard to give a simple answer. Many changes have taken place with civilian rigs and glow plugs. With the military - not so much. I assume because the military doesn't want to deal with constant changes in part #s.What is the BEST glow plugs to get
Try parking downhill and see if that remedies the situation.With my new acquisition (m100Ive noticed it's common for the truck to fire up and die when cold. It is usually difficult after that to get it to fire up again. Truck has new ac delcos with a good 12v supply to them. The truck isnt plugged in or at least the plug heater doesnt appear to make a difference when plugged in. I assume it no longer works. What Im guessing is my problem, along with some of you other guys, is theres a little air leak in the fuel line. Both my blazer and the pick up have manual gp heater buttons installed. The wellmans (24v version) in the blazer always seem to fire it up with about a 15sec cycle but the pick up takes much longer, more like 30sec. It usually races for about 2-3 sec and then sputters and dies putting out white smoke like thers alot of unburned fuel. Once I get the first start of the day out of her she usually fires up for the rest of the day quite easily, even after sitting for 3-4hrs. I might have to hit the gp button for 5sec if the pick up doesnt fire off of the starter alone but if I do it starts immediately.
My long winded point is make sure you dont have air in the fuel line. It makes starting much harder.
I'll give it a try and see what happens. Thanks50Shooter try this:
Get in the truck and crank it immediately without cycling the glowplugs (Or if your gp system is intact) before the plugs have a chance to cycle. If theres a small air leak in your fuel line this should purge the air out. May have to do it a little longer if you havent started it in awhlie. Then cycle the plugs a few times, making sure theyre hot. after 2 cycles or maybe 2 - 15 second bursts (5sec in between) on the gp button try starting it. I'll bet she fires up. Plan on changing some fuel line or a filter mount or even a lift pump around June.
