How far can a M109 tilt to the side?
Darwin T
12
Port Arthur, Texas
You will know when you have gone too far because you will hear a voice that sure sounds like your own yelling OH S***!!!!!!
If you have your significant other with you then you will probably never be able to hear much again shortly after that scream!
Rick
wrong, if you have your significant other with you then you will hear about it every day and you will never hear the end of it. :whistle:
OPCOM
29
Dallas, Texas
from that document:
Although 25 degrees is a severe roll angle for a truck the size of the M35A2, it is only about half the angle required for the truck to roll over.
I don't want to try it. The 5 ton might be a little better due to weight (but not with taller tires).
Seems the pucker gauge, which sets off alarms much sooner than 25 degrees, is a good instrument.
jesusgatos
on the road - in CA right now
25-degrees? I think motorcoaches and OTR trucks are supposed to be able to handle up to at least 35-degrees. The military has to have commissioned some kind of tests of these vehicles. Nobody has seen anything? here's a document that outlines some rollover testing procedures for larger vehicles.
SMOKEWAGON66
21
California
oohhh...I can answer this question. The M109 will tilt only as far as it takes to tip it over. Then you'll know youve gone too far lol...But seriously though, just use common sense. If it feels like its listing too far, dont go that way. It may have an angle that it will generally go over at, but you may have more gear stowed in your van, or more fuel in your tank, or less tire pressure in your tires then the truck they tested the angle out on...plus forward motion will add to the weight being tossed side to side when your suspension travels. i.e. if you know the 109 will tip at say 60 deg when standing still, whos to say she wont go over at 49 deg because you hit a bump and flung weight above that center of gravity....
LowTech
162
Arizona
w/ the rear suspension made the way it is, we almost never have things tossed about in side.
I have seen Elise tilt it so much that it freaked her right the sh!t out! I saw it in my mirror and all I could think was DON'T STOP!, DON'T STOP!, DON'T STOP!
That was before we had the Hemet rims and 395's, . . . it was singled w/ flipped hubs and the rims dished in.
This was me the next day and I didn't even come close to what she had done
Rodger
Placitas, New Mexico, USA
Hey Low Tech
I really enjoyed your pictures of the Death Valley trip in the M109 & how you set the camper up, and the roof rack .
Can you explain why you singled the stock wheels?
Thank you
Rodger
Thank you
