How to wire electric brake controller
svlsmokey
N/E Calif.
Not finding anything searching for this so maybe you can point me in the right direction or give some guidance on how to wire up the under-dash part of an electric brake controller for standard 7-pin connector. Thanks all.
Warthog
227
OKC, OK
Same as a civilian truck. Tap into the brake light wire. The brake switch and lights are all 12v.
JJP
Erie, PA
If your looking for basic install how to Try Etrailer.com. They have quite a few how to videos. I used some information from them for mine on a 76 chevy. They had a video on installing one in an older chevy.
Swamp Rooster
Hayward WI
When you run your wire to the battery just make sure it is not where it doubles up or your brakes will just stay on and eventually the controller will burn up... Swamp Rooster.
