Hawk, here is the listing I found for that filter: ( I did a Fram cross)Wanted to check with the HUMMVEE guys if anyone would know if a Baldwin B7042 filter is correct for this vehical......I tried to Google and check online for info but didn't get anywhere. Thanks
NO that filter has metric threads so it will not work, the correct filter will have 13/16-16 threads.Wanted to check with the HUMMVEE guys if anyone would know if a Baldwin B7042 filter is correct for this vehical......I tried to Google and check online for info but didn't get anywhere. Thanks
Thanks for the answers! I still have like a hundred of these things left so all the help is appreciated!NO that filter has metric threads so it will not work, the correct filter will have 13/16-16 threads.
I have found the best place to cross over various filters is the WIX filter lookup, and those are the only filters that I have normally used for many decades.
You can start by looking up a 1995 HUMMER with diesel engine then you can use the cross to see if whatever filter you have crosses to the same Wix number, not totally foolproof but pretty close.
