Humvee rear differential shims and parts needed
Al Capone
Pearl river la
I've heard bunch of times this is a model 20 basically rear diff . But also have found some listings for 1999-up h1 diff parts ? I want a ring gear shim kit so I can tighten up so slope and also bearings and seals . I've tried few vendors for the military part number shim kit and no luck . Can anyone give first hand experience on what shims they used for carrier ? My 998 is 1990
Al Capone
Pearl river la
I've cross referenced carrier bearing numbers and such and found all them . And 76-86 cj7 jeep uses same carrier bearings , so in theory should use same shims . Better than the $223 am general shim
kit I did find !
Action
1,561
East Tennessee
5579453 is the AMG set listed at LYNCH for $145.65.
Or, you can buy the specific shims you need (40 different thicknesses) from $3.85 - $6.58 each.
