res0wc18
- 2
- 18
- Everett, Wa
So i am going to be putting a mile marker hydraulic winch on the duece, and i am considering two options for the power source, well three i guess. The first is a hydraulic clutch pump like this High Pressure Hydraulic Clutch Pump — 2.32Cu In. | Pumps | Northern Tool + Equipment
The second is the ford super pump from AGR Welcome to AGR Perfomance, Inc.
The third which is one some may not know about is a dc powerd hydraulic unit, that is usually used for dump bed kits. They have the option for what is called a 6 way power valve built in which could power the winch as well as the dump bed im going to put on. Of course the rest of these could as well. something like this Haldex 12 Volt DC Power Unit — Manual Operation, Double Acting, Model# 1510038 | Power Units | Northern Tool + Equipment
That would be spining much more flow running on 24v though
What do you all think? Anyone done hydraulic winches?
