barryblakely
- 0
- 0
- Seneca, SC
Had a lead develop from my hydro-boost...what appears to be the "in" hose from the power steering pump. It's leaking around the pipe, not the threads, so it's obviously a bad o-ring. Well, I took the house out, swapped the O-ring that is on the end of the pipe, re-installed, still leaking. Attempted a few more times, tightening a bit more, etc, etc...still no luck. I finally pulled it out one last time and ANOTHER o-ring came out with the first one...as if it was down in the hydro-boost and got stuck on the line this time, as I pulled it out. Can anyone id where the second o-ring goes, down in the hydro-boost sleeve? Does anyone have a link to a diagram of the hydro-boost that would show the O-rings? Thanks!
