- 17,954
- 26,875
- 113
- Burgkunstadt, Germany
According to someone I just asked, this is a modified PU-798A. It was not issued with a tool box. The TM you posted is for the trailer frame, the PU has another TM, should be TM 9-6115-660-13&P. There are several more adoptions to the trailer mounted 5KW gen set. Most are modified for a specific weapons system. Hence with or without certain items, or with certain items in addition to, the normal PU or PP setup. The way the gen set is mounted, may or may not be wrong. Certain setups were slightly different due to adding lots of gear. Like cable reels, antenna masts, antenna base's and so forth. Have to know what primary weapons system this was issued for. When you crawl under it, be sure to find the 4 gen set mounting bolts, and tighten them up.
