I got M1102
1,161
This is it, please read the manual. BTW this picture is a M101A3 but the trip is the same as a M1102
MWMULES!!!! RUN!!!!!!!! There are aliens taking pictures of your trailers!!!
I want to believe!
glcaines
2,794
Hiawassee, Georgia
Larry,
There is a built-in shock absorber that works in conjunction with the lunette movement. This shock absorber dampens the movement of the lunette so that the trailer brakes are not repeatedly engaged and released while slowing down. If the shock has failed, the trailer brakes will continuously cycle off and on causing a very noticable jerking. This repeated action can also cause the brakes to heat up because the brakes are repeatedly engaged. This is a common problem with surge brakes on MV and other trailers. You may not have any problem with the brakes. I would recommend going ahead and pulling the brake drums to check everything out and re-packing the bearings as this is good PM on a recovered trailer anyway. Clean any rust out of the drums. Check for leaking wheel cylinders and brake fluid or grease on the drums. The brake system on your trailer is very simple and easy to work on.
LMT19
Rockville, Maryland
Larry,
I will try. But I need additional two Jack stands to ensure jack space to work. Considering cost wise and title inspection, I may have some professionals done the work. Thanks a lot!
LMT19
Rockville, Maryland
Any indication of Bearing wrong?
Beltfed34 on ebay sells the wheel cyinders for the M1101 series trailer cheap.
I have taken two pictures for bearings. I wonder if anyone can tell me the sign of wrong or I just buy new sets of bearings to replace them. The grease color is brown not white cream (due to high temperature?) Is this regular bearings that I can get from any auto-shop?
Thanks,
emmado22
168
Mid Hudson Valley NY
Yes, they are Timkens, availible anywhere. I'd replace the ones you have. Rust and bearings is NEVER good. Clean everything else up really well.
LMT19
Rockville, Maryland
where to get brakeshoe pad?
I took off wheel/drum, one is good and just clean everything and lub. But other one, brakeshoe bad (top) so I need to replace it. I wonder if you know where to purchase for M1102 trailer?
Thanks,
Larry
LMT19
Rockville, Maryland
LMT19, how is your trailer coming along?
I have taken off the wheels and re-adjusted and lubricated a few components of brakeshoes because when I turn the wheel I hear something creaking, which indicated something wrong in brakeshoe. Main problem I identified was the end of the handbrake cable stacked and did not release to the right position. So it causes creaking when wheels turning. After re-adjust brakeshoes, creaking sound gone. But I have not done to HYDRAULIC BRAKE ACTUATOR ASSEMBLY MAINTENANCE. It looks a little complicated.
Note: all components in Military trailer are much better than any other in the market, including bearings, seals. So avoiding to replace or change even some parts can be purchased from etrailer or other places in very good price.
It was an interesting experience. I may purchase another trailer and to do the same.
