I have joined the club ! And yes I have lost my mine !
1951M1078
185
Glendale,AZ
Some inside work. Finished the floor to the roll up door. But it is going to be replaced with a tilt up door but that will come at another time.Will need to build a filler at that time.
Also installed some foam for the walls.
coachgeo
3,547
North of Cincy OH
.... Finished the floor to the roll up door. But it is going to be replaced with a tilt up door but that will come at another time. Will need to build a filler at that time....
One solution saw a fellow use was to keep roll up.. but just behind it put it a false wall with full insulation. Opening roll up door exposed a nice cosy cute entrance. Could see this being done deeper in leaving the area between this false wall and roll up as a garage of sorts or if done with less space ... simply a mud room and a few places for wet clothes shoes etc. Just an idea to mull over.
Great job.
1951M1078
185
Glendale,AZ
Today the truck got new shoes ! Thanks,Wes.
Install was done at Purcell's Tire. Thanks to Chris for all the work. If you need tire work,go see them.
agazza2
33
Ahwatukee, AZ
Definitely want to what you figured out. I will be rotating mine 180 degrees and see if that helps. For testing I need to drive to either that hill or to Payson. Might be a few weeks as I have the interior torn apart for some sound proofing & heat deadening.
1951M1078
185
Glendale,AZ
Yep,built the bar for the lights and need to finish the rest of the guard that will go over the cab. I'm slow.
Read the plate in a mirror. 8701MYM + MYM1078 or My M1078. LOL I know the "7" is backwards.
