I have these seals, and I can't remember what they go to...
Jeepsinker
470
Dry Creek, Louisiana
I have a stack of skf 15207 seals, and I know I've bought them for my deuce before but I can't for the life of me remember where they go on the truck, unless they might possibly be inner front axle shaft seals. I did search that and came up with nothing. I know it isn't for the winch, already checked that. I seem to remember it crossing from another number, but I've bought so many napa seals I can't remember anymore. It scrambles my noggin when I try to remember and I start to drool on my boot. Anyone else recognize the number, or recognize it from the pic?
Edit: It may be for the brake side of the worm shaft on the winch, but I can't cross it to Newstar numbers, and I don't have my winch apart to compare.
frank8003
4,990
Ft. Lauderdale, Florida
Wheel seal differential pinion seal or you can use it on your Navistar or Triumph TR6. Pinion Seals for a Rockwell 2.5 ton axle?
Made by Timken for SKF? CR is "Chicago Rawhide".
Jeepsinker
470
It isn't a pinion seal for the deuce. Way too small for that in a couple of its dimensions. What bothers me is that I know this is for the deuce... it almost has to be an axle shaft seal, but the inner diameter seems small for that.
Wildchild467
59
Milford / Michigan
Do these specs match your seal?
[h=1]Shaft Seal, 1-1/2x2-11/16x1/2", CRW1, NBR[/h]by SKF
[h=4]Technical Specifications[/h]
Zoro #: G9395556 | Mfr #: 15207
Seal Type: Single Lip with SpringInside Dia.: 1-1/2"
Item: Rotary Shaft SealDesign Code: CRW1
Lip Material: Nitrile RubberWidth: 1/2"
Outside Dia.: 2-11/16"Zoro Number: G9395556
Mfr Number: 15207
[h=4]Product Description[/h]
Rotary Shaft Seal, Seal Type Single Lip with Spring, Shaft Dia. 1-1/2 In., Width 1/2 In., For Bore Dia. 2-11/16 In., Nitrile Rubber Lip Material, Design Code CRW1
Jeepsinker
470
Ok, so it isn't an axle seal either. The inside diameter is too small. I just found a new seal and retainer hiding in a box to compare it to. Maybe I bought one for something else a while back, and I just recognize the number. Sometimes I swear I'm losing my mind.
