I need an alternator.
westexhunt
San Angelo/Texas
I have had the deuce for a week now and have done some work on it and some driving around the farm. I used the service manuals in the resources section and have been all around very pleased with this website. I figured out this morning that the alternator is defective. I did some searches but did not find what I was looking for. What should I do, find a stock replacement, rebuild this one or put on a Delco unit?
cbvet
20
Northwest (Knox) Indiana
This comes up often.
I've heard $150 to $200 to have them rebuilt. Can't even guess at new cost.
Periodically used ones are available. Members on this site will probably speak up soon.
I recently bought a 24 volt 105 amp "civilian" type alternator for $110, which I plan to mount in a Deuce with a large power inverter.
Good Luck!
Eric
CBVET
joesco
Hampstead, NH
Yes, get it rebuilt, as it is probably the regulator. Some auto parts stores provide this service or find a good auto-electrical shop in your area. Mine was a toasted alternator and was $180.00 for the rebuild job. If you can find a new old stock (NOS) alternator, plan on paying at least $400.00 for one. Good luck.
scottc
Sebring, Florida
Mine needed an alternator, I planned on putting a Delco on it, priced the delco around 200-250 I can't remember exactly. While I was at the auto parts store we looked to see what the oem replacement would run, I think it was in the neighborhood of $1,600.00. Ended up getting lucky, a buddy of mine had one sitting in his shop, he had no use for it so he gave it to me. I never thought about getting it rebuilt, that sounds like a great option.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
You think rebuilding a 60a alt for $200 is better than a 100a alt for $115? I'd go with the civy one. PM sent.
avengeusa
MI USA
I think i may go with a civvy unit
a delco 21SI, 22SI, or even a 27SI are very similar for mounting and pulley configuration
joesco
Hampstead, NH
$115.00 for a 24v alternator, grab it then! When I had to replace or rebuild, I could not find a 24v for less than $200.00 at local parts shops, but 12v Delco's sell for much less. Plus the time to fab a bracket, just wasn't the way to go for me. But seeing lots on Ebay for under $100.00 would be the way to go next time around, for sure!
tm america
23
merrillville in
where did you get the 24 volt civy alt for that price and do you have pics my alt crapped out and im starting to loose faith in the mv alts out there this is the second one now:cry:
1,807
I have 4 canned motors and each one has an alternator (luckily). One looks new. I'm reluctant to sell any as anytime I do, I end up needing one.
avengeusa
MI USA
I have a couple of good take off ones for $100 and another unit for $75 that needs the endbells replaced(I will include). Let me know if you are interested.
what would it cost for shipping to 48161?
endbells?
what are endbells? I need to be schooled, mine has a bad regulator.... got one?
avengeusa
MI USA
do a search, alternators are categorized by a "lester #"
do an internet search for "LESTER 7197" it is a GM/Delco 24 volt, 65 amp alternator that has mounting tabs which are extremely close to the original deuce alternator, very minor wire mod, and about 115 dollars should get you one
westexhunt
San Angelo/Texas
May take you up on that.
I took my alternator to a local (small town) rebuild shop over a month ago. He has ordered stators for it twice (mine is burned up) but both of the units he ordered were much narrower (over 1" narrower) than the one that came on my deuce. He happened to have two older deuce alternators on the shelf that he did not know the origin of and offered to rebuild one of those (both narrower stator like the replacement parts that he had ordered), and let me use it until he found one of the wide stator units. Do you (or anyone reading this) know where to get the wide stator. I will have to go back to the shop to pick one up and will try to get pics of both. Thanks
avengeusa
MI USA
does anyone have one of those delco lester 7197 alts on their truck pics would help and how do you like it what did you do for a pulley
the pulley from the deuce should be a direct bolt in swap.....
I will know more today
I am digging right now, it will be nice to have a near drop in swap for the guys who want a cheaper alternative than a stock item
