I need an alternator.
Ferroequinologist
Resident railroad expert
748
Liberty Hill, SC
I have had 3 alts burn out on me or come bad from GL. Each one I took to the local rebuilder, and each time it cost $20 to have him look it over, say the regulator is fried, and that he can't get them for those anymore.
Timstrucks had good take offs for $100 or so. I got a 12v and 24v hummer one I'm going to install on the 109 for a seperate 12v system (eventually)
avengeusa
MI USA
I just ordered a new, non rebuilt 22SI alternator, 24 volt, 70 amp, current production for big trucks, cheap to rebuild, like 40 dollars for all the rebuild parts......
the deuce pulley works on it, it comes with the fan, and is a 1 wire hookup, all you need to run it is to hook the charge wire to the battery terminal on the deuce
the bottom alternator mount may need ever so slight modifications to make it work, but it is almost a direct bolt in
It will be here thursday, and i will post step by step pics of the install........
bottleworks
Central NC
new regulators can be had, they are pricey, i was just quoted 175 for one, new current manufacturer
You guys need to find better rebuilders.
See:
http://www.steelsoldiers.com/deuce/7596-need-internal-voltage-regulator.html
For a source for regulators.
avengeusa
MI USA
I found a company that has the regulators, it is called obsolete parts in cinci ohio
175 each
too much
finding them is not hard, paying for them is
bottleworks
Central NC
If the place in VA is unhelpful,
you can try Southern Automotive in Pontiac, MI. (248 ) 335-5555
Their P/N is SAW-11808666 If you're looking for the regulator with NSN 2920-01-180-8666
avengeusa
MI USA
I called them first, they sent me to the place in ohio, the place in Mi near me will sell regulators to me, but want to sell me 30 at a time minimum, I do not get favor with them being a busines either, I was told on this site to get in touch with them, it was mentioned that someone had gotten a regulator from them for 60 dollars or so, but no luck for me there
avengeusa
MI USA
obsolete parts
Cinci Ohio
513-731-4134
I already have a new unit on the way, I will repair this one for a spare
Michael
24
Fulton, MS
What was the price for 30? We might could do a group buy?
jfccac
syracuse
I'm interested in this install...please keep us updated with your progress...
neb4x4
Cedar Creek, NE
One reman on e-bay right now for .......$$$$........ Check it out @@@@@
ITEM #### 130298724639
I almost bought one the other day, just to have around in case... But.............
tm america
24
merrillville in
i checked my local rebuilder today he said he had the delco7197 for 160 wasnt to bad. considering i wouldnt have to waiy for shipping he would have it to me in an hour.plus i believe it have the pulley.
avengeusa
MI USA
OK,
Mine is up and running, there are some changes........
First
the shaft size is wrong, the std deuce alternator has a 5/8 shaft, the alt I used (22SI) has a 7/8, so i bought a pulley......
You MUST use the deuce pulley spacer from the std deuce alternator to get the correct pulley alignment
A large washer could be made to work, or i can make you one if you do not have one
the front mounts are fine, the rear mount is off, the j-mount alternators have a 4 inch spacing between the front and rear mount
The rear housing of the alternator is in a bad spot, you must rotate it counter clockwise to clear the std deuce block mount with the std deuce diameter pulley
If you have a pulley which is aftermarket and smaller than the std unit you will need to completely filp the rear housing of the new alternator, yup, a 180 degree spin
No wiring harness mods are needed
I can bore your pulley for free, you pay shipping, boring the pulley would be the best and cheapest route to go, I will experiment on Mine first
Mine charges at 27.5 volts and puts out 75 amps
I made 2 aluminum brackets from round stock to secure the rear of the alternator and get rid of the flexing action........
I will post pics later today
I can make brackets for you if you need them, there is an arm that will be longer, or shorter depending upon the degrees of rotation/pulley used
the bushing in the rear of the new alternator has to be removed to use my brackets, nice and solid
need any more help call me 734-682-5107, and i can get the alternators at cost
avengeusa
MI USA
Here are some pictures of the whole thing, simple, easy, and rock solid, I used a more expensive alternator than i had to, why? I have no clue, but the unit has the same mounting as the lester number listed above..... simple j-mount unit
The unit mounted with the longer of the two brackets, you can see both parts i made to make for a very simple install
The unit with the shorter bracket mounted on the bench with the block mount off the truck for test fit purposes
the adaptor part, this replaces the bushing in the rear of the alternator, and is held in place by a 3/8-16 tpi bolt, washer, and lock washer
the adaptor from the from, shows how it is secured
the pulley and spacer used, Note* In future I would use the std pulley and bore it out to 7/8, use the pulley and spacer, and the short bracket
I hope this helps, like i said before i am willing to help others get the parts and alternator if need be
someone tell me how to post pics.....
