- 657
- 909
- 93
- Southern Minnesota
I've got a 6.5L GEP in my HMMWV. Last Saturday I dove 2 miles into town, 2 miles back and right when I pulled into the driveway she started puking coolant all over the ground. By the time I realized what had happened, the temp gauge when from 210 to 240+. I shut it down right away, but now it's smoking pretty badly and keeps puking coolant. (Pretty sure combustion is getting into the anti-freeze, and if I take out the dip stick there is visible smoke coming out as well.)
I'm going to start calling around to see if I can find someone locally to do the repair... if that fails, I'll need to do it myself (which I REALLY don't want to do in the driveway in November in Minnesota!). I've started looking over the repair manuals (TMs), but can anyone give me an idea of how difficult this really is, and approx how much time it should be?
I'm assuming I need the gasket kit:
5714842 - Kit 12456409 - Intake and head gaskets
5714510 - Valve Cover Gaskets
5574856 - Exhaust gaskets
5740031 - 34 Head bolts (summit has multiple kits for a reasonable price)
5743238 - Thermostat
Is there anything else I can expect to need?Do the head bolts need to be replaced or are they re-used on this engine? Edit: head bolts are TTY, so need to be replaced.
Even if I end up paying a shop to do this, I want to try to make sure I have everything they may need down in a list.
