Identify These Radio Sets
maxim
I would like to know the model designation, approximate years of use and applicaton of each of these:
First, is a radio with frequency range of 200-280 Mhz on a rotating dial and presume it a ground vehicular to airborne variety. There is not a tag on it. Does this get power from a PP 109 or 112 and what would be the antenna.
Second, is a wood cased set with tubes and two locking dials "I" band and "G" band labled BC-1006-B Philco Corporation. Apparently a test set for something but what.
maxim
It is amazing the answers come from just around the corner...hey Beast thanx..I intend to use them for display in a '55 M38a1 Air Force (Strata) if I ever get it done. It was a disaster but originally came from Wurtsmouth. I already have a PP-112. Got any idea for a near correct antenna or will the 116,117,118 work? I see on yours where the data plate was and only glue left on mine.
67Beast
450
Silver Lake Sand Dunes MI.
Mine is not hooked up to the antenna right now until I find the cable jumper to hook the antenna of the R-110 through the antenna of the RT-67. I currently have the 116,117,118 to an AB-15 base mounted on a MP 50 with the corner mount. Stop in sometime when you are down this way if you want to check it out.
