hot rod deuce
- 0
- 0
- Kasota, Mn
well as long as you didnt go and cut the back axle off you need this!
What I have is pile of parts that will make your life much easier and cheaper. We are all familiar with the horrable axle bind that comes from driving any M-44 seires truck down the pavement. Some people remove the rear drive shaft, but this not only takes time and is a pain but when you want 6 wheel peal but you gotta crawl under and put it back on. Dont forget getting the flanges lined back up. I usualy wind up jacking up one wheel to get it right.
The plan here is to replace your stock axle with an Alloy double splined shaft. This will let you to put a lock out hub on said axle. (the same hub that goes on a front axle.) This will allow you to "unlock" one axle.
Thus it will no longer power but you will not be binding up either. Saving both tire wear and gas milage. Not to mention a shorter turning radius that you can not put a price on. Now the big advantage of this is that when you want all wheel drive again all you do is go turn the dial to "lock".
PM for prices with a memebrs only discount.
