Inexpensive camper/utiliy box for m35a2
718
9
Springfield Or
Test fit the compressor to make sure it will work in the space. I picked a single v pully unit so the alt and water pump will still have enough belt wrap not to slip. I did some research and found that some were having a problem with belts slipping.
Worked on the condenser lines.
718
9
Springfield Or
Built a lightweight bracket system for the AC compressor out of 1 1/8 bar stock. Its strong because it makes a triangle off of the alternator adjuster.
It has zero flex and is easy to adjust the belt tension.
Note the white dots on the AC belt. It helped me keep track of which was which while putting them around the fan. Every toolbox need a bottle of whiteout in it.
20160720_164650.jpg20160720_164636.jpg20160720_171402.jpg20160720_171725.jpg20160721_155141.jpg20160725_130912.jpg20160725_130939.jpg20160725_131019.jpg
It was time for new belts for sure.
9
Springfield Or
Went to charge system and 1 minute in SQUEEEEEEEEEEEELLLLLLLLLLLL. No ride home in nice cool air. The idler bearing locked up on the reman compressor. A/c will have to wait till next week.
718
9
Springfield Or
Installed the replacement AC compressor and vacuumed down the system. Charged with 2.75 lb
r134a and the air got real cold.
The real test will be the drive home. I don't know if the blower can move enough volume through the stock heater ducting. Also I realized I have no means for recirculating the air. So, will it put out enough cold that it's not needed? Stay tuned for the answer.
Starting temp and finished temp
Ac and heater controls. High low fan switch, hot water valve and A/C switch
Found some of the old fashioned fiber reinforced tar tape to plug holes in the firewall.
718
9
Springfield Or
The under hood evaporator did not work. It would blow nice and cold when idling but when the engine started working the poor thing was overwhelmed by the under hood temperatures.
So I bought a under dash unit off e bay for $99 dollars and it works great. It was a little to long so I had to notch it so the map box would open. I did paint it to match but have no photo.
20160906_165603.jpg20160912_093314.jpg20160912_093924.jpg20160912_093915.jpg20160912_140039.jpg
718
9
Springfield Or
Cut one of the old tires in half, was curious of how they were built.
Mounted four more tires with good tread. Years ago I bought this 3/4 drive electric impact. I keep it in the truck. A lot easier to plug it into the power inverter than wait for the air tanks to pump up.
And then there is this tank heater I installed. I hope that it makes the truck a little more responsive when its cold out. The warm oil should flow through the filters better. For those that don't know Its going on five years of running 100% used oil. It's still my daily driver.
718
9
Springfield Or
The in tank fuel pump went out. This is what you will find in you tank after four years of daily driving
running 100% used oils for fuel. It's a silky sludge that with just a little help went right through the drain hole.
rustystud
3,392
Woodinville, Washington
View attachment 688233View attachment 688234View attachment 688232
Well one good thing about using used engine oil. You have no rust in your tank !!!
Do you have some kind of "prefiltering" of your oil ? Like it goes through a filter into a 55 gallon drum, then gets pumped into your fuel tank ? I was thinking about doing something like that for mine. I have hundreds of gallons of used engine oil saved up and plan on using it in the deuce someday. Of course with diesel so low in todays economy it is not worth doing right now.
718
9
Springfield Or
I use to filter it through a 5 micron shock filter then into a barrel to be pumped through a filter and a water blocker. I now just dump it in a barrel and pump it through a water separating fuel filter. I save the used ones off my truck and run them until they plug up. (I have change of course over to spin on filters)
I use to cut the filters apart and found really no differences just going through one filter compared to three. The fine soot just goes through them all
rustystud
3,392
I guess the centrifuge cleaner is the way to go then. Costs to much for me right now though.
718
9
Springfield Or
Time has been hard on the paint and the counter top.
I calked the counter and started touching up the pealing paint
Also started a access cover for the shower faucet.
More to come.
718
9
Springfield Or
And installed the cover I made.
My frig is freezing on 110 volts so that's the next project. I want to repair it because I like having the vintage stuff.
If any of you happen to have a wiring diagram for a Dometic RM 45 frig please let me know.
77 AMG
62
Owingsville, KY
Wow. Just wow. Really impressive work, mobileauto2000. I showed some of the pictures to my 17 y o son, and he currently busy with graph paper, working up plans for "his" Deuce. Once again, impressive work!
718
9
Springfield Or
Tested the house battery's and they were down to 50%. I checked the output from the charger inverter. It was 9 volts.
Pulled the inverter out and looked through the vents and saw this.20190809_111808.jpg
I cut an access hole and soldered the wire back on. No change still 9 volts coming out.
The truck also has a solar panel. When I put it in I used a cheap solar charge controller. Think it cost like nine dollars. Pulled the panel wires and tested the voltage. It was at Nineteen volts. So I ordered a new controller.
I installed the new controller and a volt amp display. Hooked up the solar panel and the output was only 9 volts. Whats up with the 9 volts anyway?20190810_124508.jpg
I went around the corned to Harbor freight and bought one 25 watt solar panel for testing the wiring and controller.
hooked it up and the battery's were charging. Yay.
Next went on amazon and ordered a new charger inverter and a 100 watt solar panel. Installed them both and my battery's are charged and happy
A foot note on the Harbor Freight solar panel They are over priced but work well in low light conditions.
