Inexpensive camper/utiliy box for m35a2
rustystud
3,331
Woodinville, Washington
718
9
Springfield Or
Yes I would. It saved a lot of framing work.
Now if I had deep pockets I would have built from scratch with fiberglass skins and a nice rubber roof.
I am currently trying to find a way to get a smooth surface on the plywood siding so it will look more like metal. (At little or no cost)
rustystud
3,331
Have you tried "Bondo" ? My good buddy did that on his camper and it worked fine.
OldDuke6
Tahlequah, Ok.
If you need to do the roof, I highly recommend using any generic aftermarket automotive truck bed liner. Its paintable, tough, and will last forever without cracking, as it has built in UV blocking properties.
I redid the roof on my parents 38' Eldorado Rv, and it lasted 10yrs until they sold it. It survived hailstorms, tree branch strikes, wind, saltwater, and also strengthened the roof, allowing us to use it for relaxing like a patio.
ROCKWELL-C60
192
franksville wi
Be careful on which bed liner u use previous owner of my m146 used roll on liner and now it leaves very hard to get off streaks down all sides of my new paint job. He also used black which makes roof so hot you can here it buckle.
99nouns
17
Ocala, FL
Please explain more I am really intrested on this idea, I can probably coad it with elastic roof sealant in white color?
718
9
Springfield Or
I used a roll on roof sealant after I calked and sealed the seams with RV seam sealer. The roof is aluminum.
I have noticed a little moisture around the refrigerator. After some investigation it appears a branch hit the vent pretty good.
Time to get out the extension ladder I guess.
99nouns
17
Ocala, FL
Did you use the truck bed liner at all?
718
9
Springfield Or
No.
I find that a product designed for an application usually works better than one that's not.
I have had experience with the brush / roll on bed liner and it's not even close to the professional stuff. Found it had a vary short life span for it intended purpose, would not wan't to trust my roof to it.
718
9
Springfield Or
Started the camo
20160618_114626.jpg20160618_131050.jpg20160618_123603.jpg20160618_133929.jpg20160618_135850.jpgView attachment 629839View attachment 629838
I find that a roll of electrical tape works good to protect reflectors from paint.
Also I have seen questions about Krylon or Rustoleum paint.
The color is so close between then that I use them both on the same job.
Krylon is easier to spray but Rustoleum last longer in the elements.
So base coats Krylon final coat Rustoleum.
9
Springfield Or
Made bracket for accumulator, Added pag oil and installed in truck. Also installed a valve in heater hose.
20160711_124655.jpg20160711_130650.jpg20160711_130643.jpg20160711_142256.jpg20160711_142313.jpgAt some point I will have to deal with the top of the evaporator box being uneven.
It bothers me. Wished I had noticed when I screwed it on.
9
Springfield Or
Mounted the condenser today. I got lucky or God was looking out for me. The condenser is the same with as the radiator so I was able to screw it right to the radiator sides.
The radiator slopes and the bottom is closer to the brush guard. So I cut the cross bar loose and welded it in pulled a little forward.
20160713_154518.jpg20160713_154528.jpg20160713_171943.jpg20160713_171935.jpg20160713_162507.jpg
QUADJEEPER
Winter Springs, FL
View attachment 633276View attachment 633275View attachment 633277
View attachment 633274View attachment 633273View attachment 633270View attachment 633271View attachment 633272
Nice install. What condenser did you use? Brand, part number?
