Input requested
Tanner
11
Raleigh, NC
gimpyrobb said:
These, I don't know what they are for. I guess one might be for the fuel pump. I will need to find plugs for these too. They are in the harness between the controller end and the heater end. There is a relay in the harness too, incase anyone needed to know.
Gimpy -
Bryan Ayers here ("Tanner") in Raleigh, NC -
I'm a factory rep for PEI-Genesis (www.peigenesis.com) - sell MS connectors from Amphenol & ITT Cannon - what are the p/n's on your connectors?
"Tanner"
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Tanner, the metal plug is labeled 12s-3. The gm weatherpak connector is labeled ped32. I'd like to find ends to plug into the connectors pictured. I think the ped32 goes to ground, and the other(12s-3) is for a fuel pump. Anyone who knows for sure please feel free to chime in.
cranetruck
94
Meadows of Dan, Virginia
Gimpy, the part numbers for the connectors will be MS3101A12S-3S or MS3102A12S-3S depending on if you want cable to cable or cable to box type.
The cable clamp you'll need for the 3101 is MS3057-4A.
I don't have any of the 12S size and no single pin weatherpacks either.
Find the weatherpack connector on the page linked to, in my post above.
FWIW, wire number to the heater fuel pump is #402.
Tanner
11
Raleigh, NC
Gimpy -
Bjorn beat me to the answer! You can use the cable clamp mentioned on the connector rear-end, or put an adaptor & heat-shrink boot the cable, or ... (various options)
Tanner
