roalcoal
- 1
- 18
- poplarville ms
I like the 5 ton beds except for the part that hangs down in the back that houses the tail lights. Don't get me wrong, not bashing as I said before yours looks great. What made me decide on the deuce bed from WM is that it comes with troop seats I can't wait to see your finished product. I don't know what it is, but the tractor wheel base with a cargo bed is just the ideal set up to me.rebelqwes87 I originally was going to use the deuce bed but i had a choice between the two , I liked the look of the 5 ton better so i went with that one. I plan on painting it this weekend so ill post more pics when i am done.
We need lots of pics and description of how you do the switch back and forth once everything is ready. Are you going for a "static" shift that only can be done home or some kind of trick to switch the bed and the fifth wheel as it were "in the field".Thanks to wreckerman893 I was able to get a bed for my tractor and figured I would post some pics.of my project. I wanted a universal truck that has a multi purpose . The bed can be removed easily and the fithwheel reinstalled fairley quick.View attachment 509365View attachment 509367View attachment 509368View attachment 509369View attachment 509370View attachment 509371View attachment 509372View attachment 509373
I plan on using a 105 frame that I have and putting the 5th wheel on it for a dolly. I don't have a trailer yet but I plan on getting one and making it into a camper.10' end to end outside measurements , I havent measured it but i sure the inside measurement is dang close to 10'. I thought of puting tire rack in the bed but if i wanted to use it as a tractor i would have to take the tire rack out the bed and re mount it.
That or just run without the spare. Most civilian tractors don't run spares.10' end to end outside measurements , I havent measured it but i sure the inside measurement is dang close to 10'. I thought of puting tire rack in the bed but if i wanted to use it as a tractor i would have to take the tire rack out the bed and re mount it.
