Installing bed on tractor
4XDesign
47
Blythewood, SOUTH CAROLINA
I really like this modification. It looks great, and you could always swap back the 5th wheel if you needed it.
Has anyone seen a bed installed over the fifth wheel? I will possibly entertain an idea to try this on my next project. Not sure if there is a big enough void to rearrange cross members to make this happen.
rebelqwes87
Loganville, Ga
:tigger:
I'm glad both you guys that bought beds from me did so well. I'm in the process of downsizing the inventory and the last thing I wanted was to see these beds on a slow boat to China.
Wait till you see the mod I have in mind for the M927. I'll post it in a separate thread in a few days.
I hope to have the deuce bed I bought from you mounted before the rally. I doubt I'll get it painted though.
MWMULES
351
DESOTO, KANSAS
I put a king pin and plate on the bed so it could be removed and the 5th wheel stays mounted. Was not planning it but turned out it also works as a natural dump bed. http://www.steelsoldiers.com/showthread.php?44927-M818-I-m-trying-a-new-way-to-put-a-bed-on-it/page6
roalcoal
poplarville ms
IMAG0007.jpgIMAG0006.jpgPics of suspension flexingIMAG0008.jpgwhen I got back to the house I was parking the truck and it started to die out ,truck lost prime ,time to find a leak
racing4funn
Chattanooga Tennessee
Yall that have cut down a bed, I have my bed ready and marked. I have a saws-all, metal cutting wheel on a hand grinder, and a plasma cutter. What did yall use for cutting? I would rather not use the plasma. Its cuts wont be as smooth and would be more likely to have gaps when welding it back up..
98G
Former SSG
4,832
something to think about - take a bite out of the bed such that two of tje transverse crossmembers will be just a few inches from each other when rewelding. This will greatly reduce the stresses on the welds and will make that are the strongest part of tje bed instead of the weakest...
