Intermittent Low Air Pressure Warning Light
Engineer 1SG
Eastern Shore of Virginia
Based on the 5-ton wiring diagram from TM 9-2320-260-20, the buzzer and light are fed from the same supply wire (#85), so if the buzzer always works but the light is intermittent, check for loose connections at the #85 supply wire to the bulb, bulb contacts or in the ground wire coming from the bulb to ground.
