Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Based on the 5-ton wiring diagram from TM 9-2320-260-20, the buzzer and light are fed from the same supply wire (#85), so if the buzzer always works but the light is intermittent, check for loose connections at the #85 supply wire to the bulb, bulb contacts or in the ground wire coming from the bulb to ground.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
