Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
The oring at the base is not leaking, and i dont belive the plunger bore screw is leaking, i think the HH has a crack in it. I will pull of the tin cover tomorrow and find where the fuel is coming from.
okay, i removed the tin cover and the leak was coming frome the plunger bore screw. i removed it, cleaned the HH head and screw, reinstalled and set the torque to 55lbs..problem solved. I would like to thank everybody for there help
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
