Sparkyz911
- 61
- 33
- Central IL USA
New guy 'round these parts. I am a member of a volunteer rescue squad (Central Illinois) and have been tasked with repairing some surplus equipment, hence my joining up. (We currently have a HMMWV, ground mounted MEP, 2 portable gensets).
We have 2 UNICOR NF2D portable floodlight sets that need fuel system overhauls. Details:
NSN 6230-01-382-7265
Kubota D905-E diesel motor
7kw Kohler generator
2 big ol' lightheads
all in a 4 wheeled, pyramid shaped (sort of) housing/trailer.
These are the same ones used mostly at air bases for backup/temporary lighting.
The problem is that the old diesel has turned "algae" so the tanks need dropped and sent to be boiled out. We will also be replacing rubber fuel lines, fuel filters, and at only 1 fuel/primer pump (fingers crossed).
I searched the forums and saw a lot of manuals on MEP stuff but nothing for the NF2D. I mostly need it for the design/construction/disassembly aspect. I've scoured the corners of the net and cant locate anything. Any help?
