Jeepsinker's M35A2 6BT Cummins swap ( pics and videos)
Jeepsinker
457
Dry Creek, Louisiana
Yep nice up grade and yep looking good. Real power steering?
No power steering yet, but I have made provisions for it. The type E compressor I've installed came with an industrial power steering pump mated to the rear of it. I can't afford to do power steering right now, so I made a block off plate ( actually Larry made it) and I put the pump on the shelf until I'm ready for it. When I do install power steering I'll also install a hydromax brake system.
kubotaman
132
RI/MI
I have been following the build on Facebook and Youtube, great work. Looking forward to seeing the finished project.
Jeepsinker
457
More pictures. Feel free to ask questions either here or in the comments on my videos. Thanks to all who have subscribed!
gringeltaube
Staff Member
2,609
Montevideo/Uruguay
Good job, Garrett. Everything looking nice and clean!
I see you did change that front crossmember to the earlier, M35A1-style. Better so!
Also interesting: that particular oil pan model seems to fit perfectly for this application. Certainly makes it all much easier.
If it's no secret, post its part number and where to find such, for our future 6BT swappers.
Jeepsinker
457
I'll certainly post it for you all. It is stamped in the bottom of the pan in very large font.
Yes I was lucky to have the older crossmember in a frame section beside the shop. I made attempts to fabricate some kind of adapter for the later crossmember but it was awkward, imperfect, and the farther forward placement put too much leverage on it. The older crossmember fit the application perfectly since it moved the weight distribution point back toward the engine by several inches. I can't remember exactly how far, maybe 6-8". I'd have to go back and review some of my videos.
Also noteworthy about this particular oil pan; it looks smaller than a typical Dodge oil pan, yet it actually increased the capacity of the engine from ~3 gallons to 4, 4.5 gallons including the filter. I believe this is because the slope from front to back is more pronounced while the same area on a typical 6BT pan is flat.
Sgt Jiggins
Potato Peeler
229
Lynchburg, VA
I remember from when I put the 318 in my M37 (15+ years ago) what a pain it was to find the right oil pan. This type of info is much appreciated!
WillWagner
2,820
Monrovia, Ca.
Very cool, subscribed to your channel!
Dodge oil pans were/are less capacity, this is so it fits in the truck, glad you got a non Chrysler one. Also, did you build the engine and did what it came out of have an auto trans? The reason for asking is that with an auto trans behind it and using an oil to water cooler on it, like in a lower radiator hose, there is a plug installed in the block that shunts coolant flow through the lower hose when the stat is closed, this is to make it so the cooler has a positive flow around it when the stat is closed. If it is there, you can have a very slow warm up condition. It is located in one of the ports below the stat, behind the alternator bkt. in the block.
Your fan is gonna turn very fast!
WillWagner
2,820
Monrovia, Ca.
Somewhere I read the compressor was an E type. If you put an air dryer on it you need to put an E type compatible one on or the compressor will turn into a giant oil pump in short order.
Jeepsinker
457
Yes it came out of a 1994 Ford medium duty f700 or F800 truck with an Allison behind it, but it didn't have an oil to water cooler. There was a second temperature sensor in the place you were talking about.
I'm installing an old Haldex pure air plus dryer off an M923. Should work fine since the 939a2 series had the same compressor and dryer.
And no I didn't build it. It is a low mileage engine. I did reseal it all except for the timing case to block gasket and the headgasket.
Jeepsinker
457
Yeah, well I made a costly mistake today that makes me question my intelligence. Had the radiator mocked up in front of the engine and a friend showed up. Tried to show him that it runs now and wasn't thinking. Destroyed my brand new radiator and my fan. Super pissed at myself. And my beer fridge died, and my stereo rear outputs went out. All in the same day. Bad day.
gringeltaube
Staff Member
2,609
Montevideo/Uruguay
Yep, s**tt happens easily, when we get distracted. Blame it on your friend...:p
(Something to add to your signature, maybe? Like "... & destroy radiators"...):)
Thank God it wasn't your arm or leg!
Take care!
oboyjohn
122
Quebec , Canada
Things (good or bad) always happen in threes. Rad and fan, beer fridge, and stereo. Your three are done, so now on is clear sailing (should). By the way, great build and videos!
