cjacksoncpa
- 0
- 1
- raleigh
So I just picked up my running M1078.
Here are this issues so far:
-Cab lift doesn't lift the cab. I can see it starting to lift the cab but doesn't have the pressure or something to lift the cab.
-Tire pressure monitoring system all lights blinking.(maybe part of the same issue with the cab lift because both use the wet tank)
-Temp. light and stop light are on but the gauge is 165 to about 200 then the fan kicks in and lowers the temp to about 175. There is fluid in the lower glass and partial in the upper glass of the coolant overflow tank.
-Missing the turrent cover. Does anyone have a good line on these?
-Front glass cracked.
That's all I have identified so far. Any advice and council would be appreciated. I have been looking at the TM's so I will be starting down that path.
Also I am close to Raleigh, NC so if you know anyone in the community that has any events or get together's please let me know.
Thanks,
Thanks,
