Just picked up my M1078 so I am starting on this new adventure
cjacksoncpa
raleigh
On a side note, I need a cargo cover for my LMTV. I would prefer the 3 color camo but the stuff I am finding is really expensive. What is a good source or average price for a cover? I have the metal frame. I am seriously thinking about finding a small boat cover place and getting them to pattern my frame and having several made.
coachgeo
3,477
North of Cincy OH
Another potential source for having them made is stop by a large Big Rig truck shop and see whom they recommend local to you for making Tractor Trailer Cargo covers. The material they use and buy more in bulk of is heavier duty than what a boat shop might have access too.
cjacksoncpa
raleigh
The process continues
Update on my truck.
I rebuilt my hydraulic pump and got working
Sanded and painted my bows before I put on the new cover I bought.
I am having a turret cover built out of 1/8 inch steel and two bow supports that I was missing.
I purchased LED headlights(still in the box)
Started testing my CTIS five lights flashing from the start. No puffs of air in the manifold. There was no continuity for the pressure sensor or the P83 connector. The connector was missing the metal sleeve for the C pin. I am looking for sources for the two parts
I also put a pressure gauge on the wet tank to look at the pressure and it does build to 125psi but then moves down to around 110 within ten seconds so I must have valve stuck open or bad leak somewhere in the system I guess.
On a side note does anybody know what this wire that is coming into the cab on the passenger side. I have no idea. I added a picture of it and a new one with my cab raised.
One more question: O the annual maintenance packages that I see on the internet. I need to change all the fluids and filters soon and was wondering if anyone has used them? Are they a good deal? How do I get the right one for my truck? My engine is 3116 and my unit number is 003,303.
sargentwolf
st louis/mo
You need the LMTV service kit. MTV is the 3 axel beast, so save a few pennies and just get the LMTV one. I bought the service kit from fleabay and it had everything I needed for my truck.
Regarding fluids, rural king as low cost ATF that meets spec for the truck. Oil too. If your running red fluid currently in transmission, put ATF in there. Brown, engine oil. Read the thread here on changing to ATF.
Duckworthe
23
San Diego, Ca
"On a side note does anybody know what this wire that is coming into the cab on the passenger side. I have no idea. I added a picture of it and a new one with my cab raised."
As fro the wire on the passenger side. It could either be an radio wire or the amber strobe light wire. I had the radio rack behind the passenger seat and the wire was running down from the dash to the rack. now I only have the wire that goes to the amber strobe light cannon plug in the center rear of the cab. Yours looks like a radio power lead. Good luck and enjoy the truck.
Eric
cjacksoncpa
raleigh
Quick update on my truck. I picked up my turrent cover , two bows, and 4 H bracket that I had made. Couple of coats of paint and now I am trying to make a gasket for the turret cover by using flex seal. So I made a channel for the liquid to fill and setup. In a couple of days I will know if it works. Getting this installed will be all I have time till May. Then I will have time to change all the fluids and filters, install the lights, and chase down the issues with the CTIS system. I also got my license plate so I'm legal to drive it around.:cool:20170127_173031.jpg20170127_172936.jpg
