dabtl
- 7
- 38
- Denton, Texas
Having the hubs disengaged takes the shimmy out of the steering.Is it better to have the hubs in 4X4 all the time? Even when not in Low gear?
plus its fun looking in the mirror and seeing the front tandem spinning just a hair faster and seeing it leave black marks on pavement or dig up dirt when i turn... lotta power and torque to do that!Yes it will have some effect but not that much . I think the cons out weigh the pros for this idea how ever .
thanks for the link, I need some of them and a set of seat covers too!These go over the shift lever and transfer case lever. They keep the heat and dust out in Texas. In the land of the Yankees they keep heat in the cab. I have them on the second deuce and it makes a lot of difference in parades here in the Summer.
http://jatonkam35s.com/m35shiftboots.htm
Actually it will help exponentially. Front tire wear from push goes down drastically. Major improvement in mileage as it eliminates tire scrub from the different diameter rear tires. Rear tire circumference varies drastically. Even if you use my formula to match them, they still won't be perfect. Improves rear tire life as well. There are more gains to be had from unlocking a rear axle than installing lockouts on a front axle.wildchild unless you are running lockers it really wouldnt help , tire scrub is the problem with turning and lockouts on the rear wouldnt change that . With open diffs they can rotate freely and not bind in a turn . If your locked in the rear then yes i see your point .
I never really understood that myself, thanks for clearing this a bit. Isn't it undesireable to lock out the driveshaft in non 6x6 mode? I mean, normally it keeps the shafts and the differential moving and it seems to me that it is better when those things are in motion and therefore lubricated (axle seals, too).So it's purpose is to minimize moving parts on the front axle when you don't want 6x6 (or 4x4 for bobbers). Kinda like a Ford 4x4 with the lockout hubs and the 4wd shift in the cab, correct? I can see the purpose now.
