Keith Knight
- 2,183
- 113
- Wauchula, FL
I like that a lot. Did you custom build that? I'm looking for options for a tiny bathroom for my project, only I lack much in the way of actual carpentry skills. Hoping to find something easy to customize or that I can just drop right in.So it’s been way to long for an up date, sorry about that other things tend to come first.
The shower and wet bathroom. That’s a small/tiny sink on the right. The sink will get a granite top then the faucet. The small handle is for a hand towel. Also we will be putting granite on top of the stainless toilet cover/lid.
looks awesome as usual!So it’s been way to long for an up date, sorry about that other things tend to come first.View attachment 878179View attachment 878180View attachment 878181
This where I ran all of the electrical through the hull using Deutsch connectors. I made all the water and electrical connections to the habitat with connections that could quickly disconnect in order to remove the habitat from the frame if I need to service something. Basically I could have everything disconnected and ready to lift the habitat in about an hours time.
Fabricating the control panel and fitting the components.
The start of pulling wires.
Testing the system with one batteries connected.
Fabricating the seat frame and battery hold down.
Awesome work!View attachment 879765
Starting to terminate wires.
If you were wondering the various components are.
5,000 watt inverter
Smart battery management system / BMS
3ea lynx distributors
4ea solar charge controllers
2ea 30 amp DC to DC chargers for charging the house batteries while driving.
1ea 18amp DC / DC charger for charger the truck batteries
8ea 200amp hr Lithium batteries
8ea 325 watt solar panels
View attachment 879766Testing the system with one batteries connected.
View attachment 879767Fabricating the seat frame and battery hold down.
Finished all the electrical work. Used sliver plated copper buss bars on the batteries.
Looks amazing. I'm dreading electrical...View attachment 879765
5,000 watt inverter
Really impressive work. So clean and such great attention to detail.View attachment 879765
5,000 watt inverter
Those are linx distributors. Or something like that. They are on the victron site.
Testing the slides before mounting the panels.
Wire management is very challenging. My beautiful wife in the back ground is my right hand man, I couldn’t do this build without all of her help.
Now for the top panels.
This is a screenshot of the Victron Cerbo GX that is connected to the internet allowing me to monitor everything remotely. This is showing the last two days with the air conditioner set at 73 degrees here in hot Florida. I actually got everything up and running back in July and during our hottest summer it ran the air conditioner 24-7 and kept everything charged up.
This drawer uses 300lb drawer glides that lock in and out which doubles as a step to get into the bed.
The lid flips up for accessing whatever.
Just finished cutting all of the drawer and cabinet faces out of outdoor waterproof MDF Board.
Next, pull everything back out and cut latch hole, router the edges, sand, seal and paint..View attachment 886847
just fabricated all the aluminum drawers now to attach glides and test fit.View attachment 886848
View attachment 886849View attachment 886850This drawer uses 300lb drawer glides that lock in and out which doubles as a step to get into the bed. View attachment 886851The lid flips up for accessing whatever.
View attachment 886854Just finished cutting all of the drawer and cabinet faces out of outdoor waterproof MDF Board.View attachment 886855View attachment 886856 Next, pull everything back out and cut latch hole, router the edges, sand, seal and paint.
Have you used mdf before in an outdoor setting ? Im curious if you can make it completely moisture resistant ? I had asked my buddy that owns a custom cabinet shop about mdf when i did my truck but he steered me away from it and said he had tried to use it in some builds but it seemed to always warp after time and you couldnt use any water based urethanes or primers to try to seal it unless you were covering it with a formica type covering or wilsonart which have some new laminates that are great looking including all types of metal finishes and you may have already seen this stuff just throwing it out there ! The more the ideas the better it gets ! Great looking job !View attachment 886847
