Keith Knight
- 2,183
- 113
- Wauchula, FL
Not at all.
That grill will so go ahead and get that air robbing grill off and send it to me and i will send you a more vented grill so you wont over heat ! Just looking out for ya !Not at all.
A magnet that holds in the folded positionHow do you raise them once in the truck?Gone are the cable steps that I never could find on my way down.
I wanted a step that came out away from the truck that you could see as you’re coming down but I didn’t want it in the way while tipping the cab or while negotiating rough terrain. So I can easily swing these up out of the way and kick them back down when needed.
View attachment 898436View attachment 898439A magnet that holds in the folded position
Kieth,Gone are the cable steps that I never could find on my way down.
I actually built an electric deployable version first that would work when the door was opened. But I felt it had too many parts and hung down more than I wanted it to. So I went with a simpler design that will never fail.I like it. Was working on a way to power a set with an air motor
I think my wife would be more comfortable getting in or out with a more solid and visible step..
Hey Keith, just curious to hear your take on why you decided to go with this bracket style of mounting for the gas tank vs the conventional strap mounting for the diesel tank. Would you consider this method to be effective on the larger diesel tank as well (or even a smaller size 58 gal tank)? I'm in the process of adding a second 58 gal tank and just curious if this method is doable since I like it much more than the straps. Thanks!View attachment 887030
Finale resting place for the tank. The gas cap is getting painted, that’s why it’s not on there.
