Kinda got carried away..... M1028 rebuild
Sharecropper
1,102
Paris KY
After completing the installation of the Vintage Air system, I cleaned & undercoated the underneath of the cab. It didn't take much cleaning, as it still looked new from sitting in Arizona all its life. Still amazed at the absence of rust. Got the new drivetrain bolted in place over the weekend. Everything fit like it should, except I had to drill two new holes in the frame for the crossmember on the passenger side. Used all new Grade 8 bolts, washers & nuts. All engine mounts, including the frame mounts, were sandblasted, phosphate-treated, primed & painted with two coats of Rust-O-Leum semi-glass black. Also did the same for the crossmember and skid plate. Attached & adjusted the transfer case cable shifter, works wonderfully. Plugged-in the 4WD indicator switch and attached the speedometer cable. Verified that I had the correct blue 18-tooth drive gear in the NP241 and gray 44-tooth driven gear to correctly calibrate the speedometer with my 37-inch tires. Next I will begin to attach all wires & hoses to the new engine, in preparation of reinstalling the core support and new radiator. More updates coming.
Sharecropper
1,102
Paris KY
OK I have been asked about the PCV valve and how it will be hooked up, so here is my reply for all to see: Because the supercharger intake is at the rear of the blower, and because I mounted the centrifugal oil filter on the drivers side of the intake, the housing and in-line air filter for the supercharger had to come around the passenger side of the intake. Consequently, the CUCV PCV valve was right smack dab in the way. So to solve the issue, I sourced, on Ebay, a civilian 6.2 PCV bracket, which was engineered by GM to be located right over the passenger side alternator. However this only solved part of the problem, as the civilian bracket positioned the valve too high to be connected with the CUCV oil fill tube. I considered using a civilian oil fill tube, however that wouldn't work and still clear the supercharger snout. After thinking about the problem for a few days, I decided to simply cut the civilian bracket in half and shorten it so that the hose would connect to the CUCV oil fill tube at the proper elevation. Then I had to figure out how to connect the PCV valve to suction so that it would work correctly. The suction would need to be downstream from the air filter but upstream from the blower. I reached out to Tom Rabold, engineer at Bullet Racing in Australia, the designer of the supercharger intercooler intake for the 6.5 diesel. Tom shipped me a special brass elbow, and I drilled & tapped a corresponding hole in the underneath side of the rear blower housing. Bought the correct size hose from NAPA and hooked it all up. Worked like a dream. All this is shown in the photo below for anyone wanting to go down the same road as I have gone. Hope this helps yall to understand my red-neck engineering.
And before anybody asks, the white thing on the makeshift firewall is the 24v aircraft pre-oiler pump which will circulate oil to all bearing surfaces while the glow plugs are warming up. It sucks from the oil pan and pressurizes the galleys at the plug over the oil-cooler lines on the drivers side.
Sharecropper
1,102
Paris KY
Got the new all-aluminum radiator installed yesterday. Fit was excellent, however the overall height was approximately 3/8" shorter than the OEM radiator. I had some black neoprene rubber in the shop, so I fabricated a couple of saddle spacers to fit over the top mounting tabs which made the radiator support brackets fir correctly. Ran a SS self-drilling screw down through the brackets to hold everything in place.
Sharecropper
1,102
Paris KY
Pulled the core support back off and clamped it on my bench, then fit the new Derale #16843 dual electric fan to the radiator. This dual fan provides 4800 CFM cooling capacity, which will be helpful to pull fresh air through the intercooler for the supercharger, A/C condenser, and radiator. Also bought the Derale #16797 fan controller which features soft-start and variable speed which is determined by a sensor which is epoxied to the radiator tank. The controller adjusts the fan speed based on the temperature of the tank. The hotter the tank, the faster the fan speed with more air pulled through and vice-versa. During the fan install, had to make a few sizing adjustments, as well as to fabricate and install aluminum brackets which strengthens and attaches the entire radiator/fan assembly to the core support. Test-fit it and discovered that there was a 3-1/2" space between the fan shroud and the supercharger belt, so today I plan on pulling-off the core support and pulling out the entire drivetrain, and re-positioning the engine mounts to provide an additional one-inch clearance between the rear of the engine and firewall. This will also require drilling new holes in the frame to re-position the transmission cross-member. More updates coming.
Sharecropper
1,102
Paris KY
Today I got the drivetrain moved forward one-inch by repositioning the engine mounts on the frame platforms. Before removing the engine to do this, I marked the outline of the mounts on the platforms with a white marker, and then after the drivetrain was removed, I removed the bolts in the mounts and simply moved the mounts forward one inch, temporarily clamped them in place, drilled new holes and re-bolted the mounts in place. Set the drivetrain back in place and onto the repositioned mounts, and while my forklift gantry was still supporting the weight, I bolted the transmission crossmember to the adapter and then drilled new holes in the frame for the repositioned crossmember, while making sure it was centered between the frame rails. Used the existing holes in the crossmember as guides for my drill bit. Worked like a champ. This drivetrain repositioning provided more clearance between the rear of the supercharger and firewall, which is essential because the coolant lines from the intercooler enters & exits the manifold at the rear of the supercharger intake. The intercooler is a small radiator fit into the intake below the supercharger, see photo below. Now there's plenty of room for everything including the OEM wiring harness which runs behind the intake. Next I will begin to hook everything up. Starting to get exciting.
Sharecropper
1,102
Paris KY
Since my last post I've gotten a lot done. Powertrain is bolted in place; aircraft pre-oiler is mounted where the OEM fuel filter was on the firewall; 24vdc relays are mounted and wired back to the dash switches, as well as powered from the 24v buss on the firewall, the pre-oiler pulls 4 amps at 24v so I fused it with a 7.5 amp fuse. The other relay on the right of the photo is the 24v relay for the intercooler pump which will be mounted on the driver's side inner fender. That pump pulls 2.25 amps at 24v so I fused it with a 5 amp fuse. The custom gauge cluster is almost plumbed & wired, just need to hook-up the boost tube and run the EGT lead to the header extension. Next on the agenda is to order the new rear driveshaft from Shawn Woods. With his help, I determined that I needed to rotate the rear axle 6 degrees to be in spec. This was due to the earlier installation of the ORD Rear Shackle Flip kit. The way the Shackle Flip kit works is just how it sounds - it positions the rear shackle of the rear springs below the shackle hanger instead of above it, thereby providing 4 inches of lift at the axle. But in doing so, it also rotates the axle causing the U-joint to rotate upwards. The face of the Slip Yoke Eliminator on the rear of my custom NP241 is tilted at 6 degrees, and the angle of the future driveshaft will also be at 6 degrees, however the face of the U-joint was at 13 degrees, Shawn recommended installing 6 degree steel shims under the rear spring pack, which will cause the U-joint face to be at 7 degrees after shim installation, which will be almost perfectly aligned for a smooth-running driveshaft. Will post photos of all this when I get it done.
