Knocking noise
jim1131
36
Illinois
I finally got my humvee running but im hearing a knocking noise from the right rear axle when I took it for a drive, I can hear the noise even when the vehicle is rolling in neutral. Has anyone experienced this problem and maybe can give some advise as to what may be the problem?
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Coug
4,769
Olympia/WA
I had an issue with the brake caliper bracket bolts backing out and contacting the ends of the halfshaft bolts on both front calipers. Not exactly a knocking sound, but similar. Just something to check, along with the halfshaft bolts.
If you can grab the brake caliper and it moves at all, then this is definitely something to fix.
