Knuckle Boots
BT3583
85
New York
Now on to the rears! So I’ve taken one of the rear hubs off so far and boy was it time! It’s been a long time since anyone has looked in there. No cork gasket or gear oil resistant RTV in the spindle key way. Will be doing the full service on all four rears and while I’m in there replace all the wheel cylinders. This is my therapy It totally relaxes me when I’m able to just take my time, learn and go through everything!
frank8003
4,986
Ft. Lauderdale, Florida
If no sealer sealent found in keyway and the brakes are that clean it could mean there is no oil in the axle?
BT3583
85
New York
Wow looking at those pics I’m surprised at how clean mine is in there. All of the wheel bearing grease in the hub has pretty much been washed out by axle grease. Surprisingly the axel grease never made it past the inner wheel bearing, but luckily everything still looks good in there. I did change all of the fluids when I first got the truck, grease came out and new grease went into the diffs.
frank8003
4,986
axle grease? what did you fill the axles with?
