Kraz 255b
vtunimog
Vermont USA
Looks like a bridge carrier/layer. Tatra 813 has nearly the same variant. Kraz is a real beast. Huge truck. I can tell you shipping alone can run nearly 7-8k from Europe to the east coast (depending upon Inland points). There are maybe 5-10 in the USA
warewolf
Jarocin/Poland
If I were you, I would replace both filters with something more modern, because they both get stuck really easily. Especially the first one, which is made from paper. There is always rust or sludge in tanks of vehicles which stood not used for few years. Anything from a bus or a fairly modern truck should be fine. I have a MTLB-U with a turbo 330hp version of this engine and will replace both filters soon.
It's PMP pontoon bridge carrier:
73m819
329
gainesville, ga.
WW, do yoy have the fold out bridge unit to go with the truck, if so that would be so cool
warewolf
Jarocin/Poland
I would have to make few phone calls tomorrow. I think, that I saw them few years ago in one of Polish Army bases. Probably I will be able to source a set or two.
Wolf.Dose
10
Boehl-Iggelheim, Germany
To come back to the oil question: A 15W40 mineral oil will be fine. Otherwise in Winter you should use a 10W oil, if temperatures are blow 0 centigrade, in summer a 30W oil will do it as well. Or as mentioned, for all seasons in Greece a 15W40 oil is fine. The cheepest you can by will do it, like in a super market, 5 l about 10 Euro. At least that is the price in Germany. Or try to by the oil at an oil whole sale in a barrel of 60 l, which will cover your need at keast for a year.
Wolf
T815-8x8
Bozman MT
Only oils to use either Chevron Delo 400 15w/40 or Shell Rotella 15w/40 only oils designed and tested for 1million miles Caterpillar Cummins etc anything else is just comprise i.e short engine life, cold weather just follow factory dilution chart, just do google search you will see all the evidence to back it up.
sigo
Lieutenant Colonel
445
Leavenworth, KS
Did you get to work on it at all? Any improvements to the truck or headway finding parts?
Jim Hunter
Yes it is a runner...
We have done the very basics to it :
Clean air filter
Drain and clean fuel tanks
Add coolant as required
Check oil level
Engine work nice w/o any noise and all gears are working too.Same goes for the brakes.
Jim
As for spare parts I was unable to find ANY here...
duncan
None
What should be so special about the batteries? find out if its a 12v or 24v system (check the lightbulbs or something) and put some batteries either in series or parralel (or both is you use small ones). Maybe measure the battery tray and look for some bulky ones that fit properly.
USSR
316
USSR
I am still trying to find out the factory specifiactions for the batteries but with no luck...
USSR : could you please help ?
Thanks,
Jim
Standard battery for many vehicles in USSR.
Battery 6ST-182EM (2 pcs.) (Аккумулятор 6СТ-182ЭМ (2 шт.))
USSR
316
USSR
Designation of Battery 6ST-182EM
The nominal capacity of 182 Ah
Rated voltage: 12 V
The discharge current (DIN) 546: A
Weight with electrolyte: 56.0 kg
Weight with electrolyte: 66.7 kg
Dimensions: 522 x 282 x 243mm
Features of performance: Monoblock - Ebony, mesh cap - ebonite, cork
Manufacturer: Baltelekto, St. Petersburg
