Ladder
willysmd
KENT. UK
HI
Has anyone on here got some plans for making a ladder to get into the loadbed, the original ladders over here are way to expensive to buy if you can find one, so I thought you guys being good might have your own plans that you might pass on. :D
houdel
9
36
Chase, MI
Actually, if you get a short aluminum stepladder, say 6' or so, and create some sort of hooking arrangement so the top does not slip, I suspect that would be entirely satisfactory for what you want to do, and a light lighter than the stock boarding ladder.
willysmd
KENT. UK
Thats a good idea and possibly the easiest way to go, thanks Lee this is why I ask these questions you get answers cheers
willysmd
KENT. UK
jkelly66 said:
rofl Mike maybe you could make it swing somehow. Here is a pic of an Army issue one if you need I wilol take closer pics of it and give you all dementions.
John
Could you do that for me please I was thinking of trying to make one swing as you lower the tailgate and when in the up position lock it in position with an R clip or something, if I could get the dimensions of yourself that would be great.
jkelly66
OK here are the dementions of the ladder steps are 15 and 3/4 inches long by 6 inches 3/4 wide rails are 5 FT. 1/2 inches long and 5 inch and 1/2 wide. Here are some closer pics hope this helps
John
1,815
colyork said:
If you go with the aluminiun ladder don't forget to take it of when you back up,don't ask :oops:
Same applies with steel ladders. Thats why one of the doors on my M447 is different.
willysmd
KENT. UK
bigbee said:
In Dave Doyle's article on the M211 series in AM, he mentions the tailgates on those trucks have a step that swings down automatically when the tailgate is lowered. That might work on the drop side, or on the tailgate, either one.
Now that sounds interesting, is it posted on here anywhere by any chance??
OPCOM
27
Dallas, Texas
I use a 5FT aluminum stepladder, keeping it folded, and set the tailgate to the flat (porch) position with the chains. Then the ladder rests against the edge of the gate with one of the tailgate handles slightly protruding through the ladder. I fasten it there. now there is a nice set of steps to walk up to the bed.
